Since I am a novice at VB/VBA, I expect that I am doing something wrong. Just not sure what that is?
In an assembly drawing with views of the top level and sub-components, what does the DrawingView.ReferencedDocumentDescriptor.ReferencedDocument property actually refer to?
The API Help for this property provides this description: Property that returns the model document referenced by this view.
I thought that it would be the document associated with whatever view I visited in the program. Apparently that is not so.
Using the following, I visited each standard view in the drawing and displayed the model descriptor in a MsgBox.
Dim oSheet as Sheet
Dim oView as DrawingView
'For each standard view
For Each oView In oSheet.DrawingViews
If oView.ViewType = kStandardDrawingViewType Then
Dim RefDoc As Document
'the following only gets the assembly for the drawing document not the view document
Set RefDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
MsgBox ("RefDoc = ") & RefDoc
End If
Next 'oView
What I found was every view posted the same result for this property. Did I miss something?
Solved by rjay75. Go to Solution.
I added a bit more to illustrate my point. Using the following on a two sheet assembly drawing, the descriptor remains the same for all views, including those of individual subcomponents but the DisplayName changes for every view to show the name of the component in the view. That seems strange to me. (Inventor 2013)
Dim oSheet as Sheet
'For each standard view show label
For Each oView In oSheet1.DrawingViews
oView.ShowLabel = True
Dim RefDocName As String
RefDocName = oView.ReferencedDocumentDescriptor.DisplayName
MsgBox RefDoc & " " & RefDocName
End If
Next 'oView
I tried your code and modified a little. Its working fine for me.
I have a different views of assembly and components in a single sheet.
And using the below VBA code displays the display name for the components added in the view.
Sub Test()
Dim oDrwDoc As DrawingDocument
Set oDrwDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrwDoc.ActiveSheet
Dim oView As DrawingViews
Set oView = oSheet.DrawingViews
Dim vw As DrawingView
For Each vw In oSheet.DrawingViews
If vw.ViewType = kStandardDrawingViewType Then
vw.ShowLabel = True
Debug.Print vw.ReferencedDocumentDescriptor.DisplayName
End If
Next
End Sub
The line
is telling VBA to show a message box with with the Document object followed by the value of the document's DisplayName. RefDoc is the actual Document Object in memory of which there is not really a printable representation. The value printed isn't the document itself rather an internal identifier of the document type. In vba if you convert a document object to a string (which is what's happening in your MsgBox statement) it shows 50332160. Different programming languages may print different things by default, usually some representation of the object type.
So you are not getting the same document object, but showing they all reference a Document object.
If you are looking to tell the difference between documents compare the FullDocumentName property.
Thank you for responding.
I wasn't having issues showing the names with the views. I was having issues understanding the value returned by ReferencedDocument.
But I see something in your line of code that poses a question that I want to research.
Much appreciated,
Thank you, this is what I anticipated being the case. Because the number coming back was the same and the display names different, it seemed to point to the one document that is active as opposed to the document being referenced by the view.
Thank you for clarifying that point.
