I am trying to export a BOM form an assembly and there are sub-assemblies in the bom. I would like to export the BOM from those sub-assemblies also is there a way to do that?
What I am trying to do is create work orders so for instance; 711-100 has the part 810-100 as well as the assembly 800-100 in it.
I would an exported BOM to list every thing that is in 711-100 (I can do this) and also list the BOM from 800-100.
I would appreciate any nudges or hints it there is a way.
Solved by Curtis_Waguespack. Go to Solution.
Hi Lance_White,
Here is a sample iLogic rule that gets all levels of the BOM. It might not be exactly what you're after, but should get you started.
I hope this helps.
Curtis
' a reference to the assembly document. ' This assumes an assembly document is active. Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument 'set a reference to the BOM Dim oBOM As BOM oBOM = oDoc.ComponentDefinition.BOM 'set the structured view to 'all levels' oBOM.StructuredViewFirstLevelOnly = False ' Make sure that the structured view is enabled. oBOM.StructuredViewEnabled = True 'set a reference to the "Structured" BOMView Dim oStructuredBOMView As BOMView oStructuredBOMView = oBOM.BOMViews.Item("Structured") ' Export the BOM view to an Excel file oStructuredBOMView.Export ("C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat) 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly 'change to false if you want to run it invisibly excelApp.Visible = True
'open the workbook wb = excelApp.Workbooks.Open("C:\temp\BOM-StructuredAllLevels.xls")
'set all of the columns to autofit
excelApp.Columns.AutoFit 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = false 'save the workbook wb.Save ''close the workbook, uncomment if you want to close the xls file at the end ''wb.Close
Thanks alot.
Really like your blog by the way, its been a huge help with learning iLogic.
hi,
it is a good code.But I want to export all part regardless of reference part os sub assembly. it doesn't export "Reference" assembly/ parts.
Kindly advice. I am not a progarmmer. Please add updated code.
regards,
nanda
Inventor 2011
Hi nandakumar.hegde,
Here is an updated example that sets the BOM structure of the occurence and the actual file not to be Reference before exporting the BOM.
I see that you have posted to several other existing threads asking the same question. You might want to remove those posts, or reply to them and point future readers to this example (assuming that it provides a solution.)
I hope this helps.
Curtis
' a reference to the assembly document. ' This assumes an assembly document is active. Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument oCompDef = oDoc.ComponentDefinition Dim oCompOcc As ComponentOccurrence 'Find all occurrences For Each oCompOcc In oCompDef.Occurrences 'if component BOM structure is reference then change it to default If oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then 'set the occurence not to be Reference oCompOcc.BOMStructure = BOMStructureEnum.kDefaultBOMStructure 'set the file not to be Reference oCompOcc.Definition.BOMStructure = BOMStructureEnum.kNormalBOMStructure End If Next 'set a reference to the BOM Dim oBOM As BOM oBOM = oDoc.ComponentDefinition.BOM 'set the structured view to 'all levels' oBOM.StructuredViewFirstLevelOnly = False ' Make sure that the structured view is enabled. oBOM.StructuredViewEnabled = True 'set a reference to the "Structured" BOMView Dim oStructuredBOMView As BOMView oStructuredBOMView = oBOM.BOMViews.Item("Structured") ' Export the BOM view to an Excel file oStructuredBOMView.Export ("C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat) 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly 'change to false if you want to run it invisibly excelApp.Visible = True 'open the workbook wb = excelApp.Workbooks.Open("C:\temp\BOM-StructuredAllLevels.xls") 'set all of the columns to autofit excelApp.Columns.AutoFit 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = false 'save the workbook wb.Save ''close the workbook, uncomment if you want to close the xls file at the end ''wb.Close
hello Curtis,
My idea is to export all parts to excel regardless of BOM structure. I tried your code still it doesn't export the reference part to excel. Please find the screen shot.
I tryied Inventor BOM export which does the same. My assembly contain about 10000 part. but excel shows only 8000 parts.
thanks for your suport.
Try parts only BOM View insed of Structured BOM View
oBOM.PartsOnlyViewEnabled = True
oBomview = oBOM.BOMViews.Item("Parts Only")
