Read workpoints and parts used to add dimension
2 REPLIES 2
477 Views, 2 Replies
I want to read the workpoints and parts used to add dimension in the drawing. Using VBA I can get workpoints using <Dimension>.IntentOne.Geometry.AttachedEntity. However I have not seen any way to read it in VB.NET.
Can anybody please suggest me the way to read it?
2 REPLIES 2
xiaodong_liang
the similar code should be also work in VB.NET. did you get any error or failure? I used the following code, it works well to me. It is a code within a standalone application. It asks user to select a dimension and pop out the information of the attaced entity if it is a workpoint.
   Private Sub test()
        Dim m_inventorApp As Inventor.Application = Nothing
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
        End Try
        ' Get a feature selection from the user
        Dim oObject As Object
        oObject = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick a dimension")
        If TypeOf oObject Is LinearGeneralDimension Then
            Dim oDrawDim As LinearGeneralDimension = oObject
            Dim oAttEntity As Object = oDrawDim.IntentOne.Geometry.AttachedEntity
            If TypeOf oAttEntity Is WorkPoint Then
                Dim oWP As WorkPoint = oAttEntity
                MsgBox("pt x,y,z" & oWP.Point.X & "; " & oWP.Point.Y & "; " & oWP.Point.Z)
            End If
        End If
    End Sub
Best regards,
Xiaodong Liang
Developer Consultant
Autodesk Developer Technical Services
in reply to: xiaodong_liang
Thank you.
This solution works for me.
