Is there a clean way to re-order the sheets of a drawing in VBA?
In particular, I'd like to be able to add a new sheet to a multi-sheet drawing as sheet 2, instead of as the last sheet. My thought was to add it as the last sheet, then re-order to make it sheet 2 somehow. I'd be open to a better way, if there was one.
Ben Coburn
You are able to reorder the sheets in the browser. Through the user interface, you can drag the browser nodes around to get the desired order. Through the API, the same can be achieved with the BrowserPane.Reorder method.
Cheers,
