Hi
Through addin I am importing a SAT file which has wire entities then using promote wire command putting them into a 3dsketch. Below are the code blocks in VB.net and C#. While the VB.net code works the C# doesnt. Is there something I am missing or doing wrong here?
Thanks in advance
regards
Dhananjay
VB.net
{code}
public function PromoteWires(ByVal oInventorApp As Inventor.Application,byval oPartDoc As PartDocument) as Boolean
Try
' Get the top browser node of the model pane.
Dim oTopBrowserNode As BrowserNode
oTopBrowserNode = oPartDoc.BrowserPanes.ActivePane.TopNode
Dim oRequiredNode As BrowserNode
oRequiredNode = recurseNodes(oTopBrowserNode, "Wires")
oRequiredNode.DoSelect
Dim oCommandMgr As CommandManager
oCommandMgr = oInventorApp.CommandManager
' Get control definition for the line command.
Dim oControlDef As ControlDefinition
oControlDef = oCommandMgr.ControlDefinitions.Item( _
"PartConstructionPromoteWireCtxCmd")
oControlDef.Execute
return true
Catch Ex As Exception
return False
End Try
End function
private Function recurseNodes(oTopNode As BrowserNode, ByVal strWantedNode As String) As BrowserNode
Try
recurseNodes = Nothing
If InStr(1, oTopNode.FullPath, strWantedNode) > 0 Then
recurseNodes = oTopNode
Else
Dim oBN As BrowserNode
If oTopNode.BrowserNodes.Count <> 0 Then
For Each oBN In oTopNode.BrowserNodes
recurseNodes = recurseNodes(oBN, strWantedNode)
If Not recurseNodes Is Nothing Then
Exit For
End If
Next
Else
End If
End If
End Try
End Function
{code}
C#
{code}
private void PromoteWires()
PartDocument oPartDoc = null;
foreach (Inventor.Document ODoc in m_inventorApplication.Documents)
if ((ODoc.DocumentType == Inventor.DocumentTypeEnum.kPartDocumentObject) && (ODoc.DisplayName != oPartDocument.DisplayName))
oPartDoc = (Inventor.PartDocument)ODoc;
break;
oPartDoc.Activate();
//oPartDoc = m_inventorApplication.ActiveDocument;
// Get the top browser node of the model pane.
BrowserNode oTopBrowserNode;
oTopBrowserNode = oPartDoc.BrowserPanes.ActivePane.TopNode;
BrowserNode oRequiredNode;
oRequiredNode = recurseNodes(oTopBrowserNode, "Wires");
oRequiredNode.DoSelect();
CommandManager oCommandMgr;
oCommandMgr = m_inventorApplication.CommandManager;
// Get control definition for the line command.
ControlDefinition oControlDef;
oControlDef = oCommandMgr.ControlDefinitions["PartConstructionPromoteWireCtxCmd"];
oControlDef.Execute();
private BrowserNode recurseNodes(BrowserNode oTopNode, String strWantedNode)
BrowserNode tempnode = null;
if (oTopNode.FullPath.Contains(strWantedNode))
tempnode = oTopNode;
else
BrowserNode oBN = null;
if (oTopNode.BrowserNodes.Count != 0)
foreach (BrowserNode oBN1 in oTopNode.BrowserNodes)
oBN = oBN1;
tempnode = recurseNodes(oBN, strWantedNode);
if (!(tempnode == null))
break;
else
tempnode = null;
return tempnode;
{code}
