I'm trying to select an assembly component using
ThisApplication.ActiveDocument.SelectSet.Select (compOcc)
where "compOcc" is an object of type "ComponentOccurrence," but it gives me an error "438 Object doesn't support this property or method."
Solved by nannerdw. Go to Solution.
I figured it out. I had to add the "Call" statement.
Call ThisApplication.ActiveDocument.SelectSet.Select(compOcc)
