Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Problem with Factory property MemberNameIndexInitialValue usi
1 REPLY 1
wazydotnet
313 Views, 1 Reply
When using Factory passing a value tp MemberNameIndexInitialValue in c# the compiler will not let me use a long.
I cast ant and then got a COM Error not the right type.
Any one got any ideas
API info says an unsigned long
I have tried system int, int32 ulong etc
int x = 0;
MemberNameIndexInitialValue = x;
COM Error
1 REPLY 1
int declaration work fine in c# but you cannot assign zero value to MemberNameIndexInitialValue property. It must be >= 1, otherwise you get runtime error ("The parameter is incorrect...").
The following code works for me:
PartDocument oiPartDoc = (PartDocument)ThisApplication.ActiveDocument;
iPartFactory oFactory = oiPartDoc.ComponentDefinition.iPartFactory;
FactoryOptions oOptions = oFactory.FactoryOptions;
int x = 9;
oOptions.MemberNameIndexInitialValue = x;
oiPartDoc.Update();
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
