I have some code to insert a barcode image generated by something else, but the image always inserts below the drawing on the left side. Is is possible to specify a location when inserting it or move it after it's inserted? Thanks.
'Create a file descriptor Dim oRefOleFileDes As ReferencedOLEFileDescriptor 'Set it to an image "path" is the full file name Set oRefOleFileDes = oDoc.ReferencedOLEFileDescriptors.Add(path, kOLEDocumentEmbeddingObject) 'Set the name of the barcode image in Inventor oRefOleFileDes.DisplayName = "BarCode" 'Make it visible oRefOleFileDes.BrowserVisible = True oRefOleFileDes.Visible = True
