Can you guys help me to fix this code. In multi sheet this code is working with little problem. It won't stick to the border. It just stick to the sheet size on the right. Place would be good if right side stick to the border. Table sit on the top of title block which is what i want.
Apreciate for help.
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 12500
StartFragment: 314
EndFragment: 12468
StartSelection: 314
EndSelection: 314
SyntaxEditor Code Snippet
' add partslist table
oDrawDoc=ThisDoc.Document
'Set a reference to the active sheet.
DimoSheetAsSheet
oSheet=oDrawDoc.ActiveSheet
' Set a reference to the first drawing view
DimoDrawingViewAsDrawingView
oDrawingView=oSheet.DrawingViews(1)
oPlacementPoint=ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height)
' Create the parts list.
DimoPartsListAsPartsList
oPartsList=oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
minXpoint=oSheet.TitleBlock.RangeBox.MinPoint.x
minYpoint=oSheet.TitleBlock.RangeBox.MaxPoint.Y
maxXpoint=oPlacementPoint.x
dPointx=oSheet.PartsLists.Item(1).RangeBox.MinPoint.X-minXpoint
dPointY=oSheet.PartsLists.Item(1).RangeBox.MinPoint.Y-minYpoint
maxYpoint=oPlacementPoint.Y-dPointY
Dimnewmin, newmaxAsPoint2d
newmin=ThisApplication.TransientGeometry.CreatePoint2d(minXpoint, minYpoint)
newmax=ThisApplication.TransientGeometry.CreatePoint2d(maxXpoint, maxYpoint)
oSheet.PartsLists.Item(1).Delete
oPartsList=oSheet.PartsLists.Add(oDrawingView, newmax)
Solved by GosponZ. Go to Solution.
Just fixed :). Working good now in multi sheets place part list table on top of title block. Lower rh corner
DimoSheetAsSheet
DimoBorderAsBorder=oSheet.Border
IfNotoBorderIsNothingThen
oPlacementPoint=oBorder.RangeBox.MaxPoint
Else
EndIf
