Hi folks!
I'm tying to create a rule this checks all the open files, and exports a PDF of any .dwg or .idw files that are open. I fould some code on the boards and cobbled something together, but it does not work as expected. I have included the code below and as an attachment for easy use. what should happen is call the file manager and and collect all open docs, for each loop trjough each, and if it is a drawing file, export PDF. What actually happens is it exports he doc that the rule was lauched from as many times as there are open drawing docs. Please tkae a look at the code and provide some guidence! this is a big deal for us! Without further dissembling, here is the code:
fmgr = ThisApplication.Filemanager
For Each file In fmgr.files
doc = ThisApplication.Documents.ItemByName (file.fullfileName)
' path = ThisApplication.Documents.ItemByName (file.path)
If (doc.documenttype = kDrawingDocumentObject) Then 'Found an dwg
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = oPath & "\PDF"
MessageBox.Show(oFolder, "Path")
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" Rev" & oRevNum & ".pdf"
On Error Goto handlePDFLock
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
' MessageBox.Show("crap", "Name")
Next file
Exit Sub
handlePDFLock:
MessageBox.Show("PDF could not be saved, most likely someone else has it open", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
'Show message box
MessageBox.Show("Drawing saved and PDF Exported to LAST EDITED document folder/PDF", "Save I-logic")
Solved by Curtis_Waguespack. Go to Solution.
Hi truscher,
Here is a modification of the rule that I think will do what you're after (attached is the same rule in a *.txt file in case it helps).
I hope this helps.
Curtis
Dim oDoc As Inventor.Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If (oDoc.documenttype = kDrawingDocumentObject) Then 'Found a drawing
'find the postion of the last backslash in the path
oFNamePos = InStrRev(oDoc.fullfileName, "\", -1)
'get the file name with the file extension
oName = Right(oDoc.fullfileName, Len(oDoc.fullfileName) - oFNamePos)
'get the path of the folder containing the file
oPath = Left(oDoc.fullfileName, Len(oDoc.fullfileName) - Len(oName))
'get the file name (without extension)
oShortName = Left(oName, Len(oName) - 4)
oDataMedium.FileName = oFolder & "\" & oShortName & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
Next oDoc
'Show message box
MessageBox.Show("PDF(s) exported to: " & oFolder , "iLogic")
Exit Sub
handlePDFLock:
MessageBox.Show("At least one PDF could not be saved, " _
& "most likely someone else has it open.", _
Resume Next
