I`m pretty sure it is simple I just need a little help.
I have an iLogic assembly for 2 parts that make a stub up. Using form to configure it.
Here is the rules that make magic:
1st one makes sure that user saves it as new assembly, runs automatically when iam file is open.
'AC 2014 Stub up assembly configurator Dim SFD As New SaveFileDialog() SFD.InitialDirectory=ThisDoc.Path SFD.Filter = "*.iam files (*.iam)|*.iam|All files (*.*)|*.*" SFD.FileName="XXXXXTSA001" PN=iProperties.Value("Project", "Part Number") If PN<>"iStubup sleeve MASTER" Then ' do nothing Else MessageBox.Show("PLEASE SAVE IT AS DIFFERENT ASSEMBLY NUMBER, FORMAT [XXXXXTSA001], WHERE XXXXX IS JOB NUMBER", "WARNING",MessageBoxButtons.OK) If SFD.ShowDialog()=DialogResult.OK Then ThisDoc.Document.SaveAs(SFD.FileName , False) iProperties.Value("Project", "Part Number")=ThisDoc.FileName(False) 'without extension iLogicForm.Show("CONFIGURATOR") End If End If
2nd code fires after user hits Apply or OK button on the form
'АЛЕКС ШМИДТ 2014 Stubup configurator Imports System.Windows.Forms Parameter("End1", "Width") = Width Parameter("End1", "Height") = Height Parameter("Side1", "Length") = Length Parameter("Side1", "Height") = Height Parameter("End1", "FlangeW") = FlangeW Parameter("Side1", "FlangeW") = FlangeW Parameter("End1", "ShThk") = ShThk Parameter("Side1", "ShThk") = ShThk iProperties.Value("Summary", "Title")=JobN & " STUB UP SLEEVE ASSEMBLY " & Length & """L X " & Width & """W X " & Height & """H" Dim FBD As New FolderBrowserDialog() FBD.SelectedPath=ThisDoc.WorkspacePath() If FBD.ShowDialog()=DialogResult.ok Then Parameter("End1", "FilePath") = FBD.SelectedPath Parameter("End1", "FileName") = EndPN Parameter("Side1", "FilePath") = FBD.SelectedPath Parameter("Side1", "FileName") = SidePN iLogicVb.RunRule("End1", "Adjusting") iLogicVb.RunRule("Side1", "Adjusting") iLogicVb.UpdateWhenDone = True Component.Replace("End1", FBD.SelectedPath & "\" & EndPN & ".ipt", True) Component.Replace("Side1", FBD.SelectedPath & "\" & SidePN & ".ipt", True) ' update all iLogicVb.UpdateWhenDone = True 'zoom all ThisApplication.ActiveView.Fit End If iLogicVb.RunRule("Area") ' ThE eNd
Each ipt. "Side1", "End1" etc has an iLogic code that allowes to save it with a given in a form Part number.
'АЛЕКС ШМИДТ 2014
iProperties.Value("Project", "Creation Date") = Now user = ThisApplication.GeneralOptions.UserName iProperties.Value("Project", "Designer") = user iProperties.Value("Summary", "Author") = user iProperties.Value("Summary", "Title") = "END SLEEVE " & Width & " X " & Height iProperties.Value("Project", "Description")=iProperties.Value("Summary", "Title") If ShThk = 0.313 Then SheetMetal.SetActiveStyle("5/16"& Chr(34)) Else If ShThk = 0.25 Then SheetMetal.SetActiveStyle("1/4"& Chr(34)) Else If ShThk = 0.1345 Then SheetMetal.SetActiveStyle("10ga") Else If ShThk = 0.105 Then SheetMetal.SetActiveStyle("12ga") Else If ShThk = 0.1793 Then SheetMetal.SetActiveStyle("7ga") End If Try ThisDoc.Document.SaveAs(FilePath & "\" & FileName & ".ipt" , True) Catch Ex As exception ' do nothing End Try
Everything works just great.
I do have a master drawing, simple, 4 views with callouts and dim`s.
What I want is to open that drawing in the background, save it as the same assembly number and replace reference with newly configured assembly.
How I have to make a call from an iam file ?
I can open drawing using:
ThisDoc.Launch("c:\Work12\Designs\PARTS\iLogic tank parts\Stubup sleeve\iStubup sleeve MASTER.idw")
I do have a code to replace reference, but this works only form idw..
doc = ThisDoc.Document Dim oFD As FileDescriptor oFD = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference("C:\File Name.iam") doc.Update()
Any help is apreciated.. Thanks.
Solved by rjay75. Go to Solution.
This is because when the rule is run it is trying to perform Replace reference on the document that called the rule.
To have it refer to the drawing file try this.
Dim dwgDoc As Document dwgDoc = ThisApplication.Documents.Open("c:\Work12\Designs\PARTS\iLogic tank parts\Stubup sleeve\iStubup sleeve MASTER.idw") Dim oFD As FileDescriptor oFD = dwgDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference("C:\File Name.iam")
dwgDoc.Update()
Thank you! It works.
That was one part of a puzzle :-).
2nd is I need to push a command to the drawing from iam to Save it As with the new assembly number. How should I do this?
or should I push the parameter with new file name to the drawing and fire rule in the drawing to save it using parameter from iam assembly ?
Thank you in advance!
Alex.
Dim asmDoc as Document asmDoc = ThisApplication.Documents.Open("Asmdoc.iam") asmDoc.SaveAs("NewAsmdoc.iam") asmDoc.Close()
This will just save the assembly file with a new name. You'd have to do the same for each componenent as well.
See this thread http://forums.autodesk.com/t5/Inventor-Customization/Run-Time-Error-91/td-p/4945930
Thank you. Yes I know this will save current iam as a new assembly.
What I need is to save idw with replaced reference as a new idw drawing with new name.
Alex
It will be the same thing. On any document call the SaveAs method. So for the drawing it would be
dwgDoc.SaveAs("NewFileName.idw")
Thanks man! This is what I added to make it work. I appreciate your help.
dwgDoc.SaveAs(ThisDoc.Path & "\" & ThisDoc.FileName(False) & ".idw", False)
oFD.ReplaceReference(ThisDoc.PathAndFileName(True))
dwgDoc.Update()
Just check the document that you're changing the reference on. If you wanted to change it on the file that was saved make sure to open the new file.
Dim dwgDoc As Document dwgDoc = ThisApplication.Documents.Open("c:\Work12\Designs\PARTS\iLogic tank parts\Stubup sleeve\iStubup sleeve MASTER.idw") 'Save File as new Document dwgDoc.SaveAs(ThisDoc.Path & "\" & ThisDoc.FileName(False) & ".idw", False) 'Close Template dwgDoc.Close() 'Open New file dwgDoc = ThisApplication.Documents.Open(ThisDoc.Path & "\" & ThisDoc.FileName(False) & ".idw") Dim oFD As FileDescriptor oFD = dwgDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference(ThisDoc.PathAndFileName(True)) dwgDoc.Update()
