Inventor Customization
New Member
Message 1 of 3 (109 Views)
New Part Units
109 Views, 2 Replies
01-11-2013 08:37 AM
First day programing VB.net API for inventor, So Yes this a Noob Question
I using code similar to add a new part to an instance of Inventor, and it works OK. The problem is it is using the Metric Template instead of Imperial Template. I have check and confirmed my application preferences and they reflect "inches". Inve is the Variable name for my Inventor.Application. Thank You in advance
    Set Part = Inve.Documents.Add(kPartDocumentObject)
New Member
Message 2 of 3 (106 Views)
Re: New Part Units
01-11-2013 08:48 AM in reply to: ped.watt
I have found a Solution by changing the code to:
Part = Inve.Documents.Add(kPartDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2013\Templates\Standard.ipt")
But is there  cleaner way of doing it?
ADN Support Specialist
adam.nagy
Message 3 of 3 (87 Views)
Re: New Part Units
01-16-2013 10:29 AM in reply to: ped.watt
You can use the Application.FileManager.GetTemplateFile to get the default template.
Like in this blog post:
http://modthemachine.typepad.com/my_weblog/2013/01/c-help-examples-for-sheet-metal.html
Cheers,
Adam Nagy
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
