Inventor Customization
*Pro
jletcher
Message 11 of 16 (150 Views)
Re: Need help creating a rule
10-04-2012 06:32 AM in reply to: fakeru
Ok I am on 2012 also so we will be fine there. I have meeting when I get out I will get her done....
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Contributor
fakeru
Message 12 of 16 (137 Views)
10-06-2012 05:59 AM in reply to: jletcher
Hi  jletcher!
Have you tried or not yet?
AIP 2014
Windows 7 x64
Dell Precision T7400 Intel(R) Xeon(R) CPU X5472 @ 3.00GHz (4 CPU's), 8Gb RAM, NVIDIA Quadro FX 5600 1536MB GDDR3
*Pro
jletcher
Message 13 of 16 (126 Views)
10-08-2012 08:47 AM in reply to: fakeru
Yes I am on it just trying to make it faster don't like the way it is updating. So I am trying a few things out.
If you go from 500L to 1000L or so lets say it takes a few minutes to complete so I am tryig a few things to speed it up should have it posted later today.
Monday is bad for me I have like 10 clients I have to go have meetings with see if they need anything then I should be able to finish it up...
James Letcher
Valued Contributor
fakeru
Message 14 of 16 (123 Views)
10-08-2012 09:26 AM in reply to: jletcher
ok. take your time, it's not urgent for me. thank you very much for your effort!
AIP 2014
Windows 7 x64
ADN Support Specialist
Vladimir.Ananyev
Message 15 of 16 (99 Views)
10-16-2012 05:48 AM in reply to: fakeru
I’ve slightly modified parameters in your model and add "optimization" rule that calculates desired height using the simplest iterative bisection (dichotomy) method.
'this rule adjust the value of Height model parameter
'to get the part volume equal to TargetVolume
'TargetVolume - target volume
'HLowerLimit - Lower heifht limit - HLowLimit
'HUpperLimit - Upper height limit - HUpperLimit
'NMax - maximal number of iterations -
'RelErr - Relative error
'maximal number of iterations
Dim NMax As Integer = 30
'Relative error
Dim RelErr As Double = 0.00001
ThisDoc.Save
Dim oDoc As PartDocument = ThisDoc.Document
Dim oUOM As UnitsOfMeasure = oDoc.UnitsOfMeasure
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oPars As Parameters = oDef.Parameters
Dim oMassProps As MassProperties = oDef.MassProperties
oMassProps.Accuracy = MassPropertiesAccuracyEnum.k_Medium
'Input data
Dim Hmax As Double = oPars.Item("HUpperLimit").Value
Dim Hmin As Double = oPars.Item("HLowerLimit").Value
Dim Target_Volume As Double = oPars.Item("TargetVolume").Value
'control height. Volume is driven by this parameter
Dim oModelPar As ModelParameter = oPars.ModelParameters.Item("Height")
Dim N As Integer = 0
Dim H As Double = (Hmin + Hmax) / 2
oModelPar.Value = H
oDoc.Update
Dim V As Double = oMassProps.Volume
Do While (N <= NMax) And (Math.Abs(V - Target_Volume)/Target_Volume > RelErr)
	N = N + 1
	If (V - Target_Volume) > 0 Then
		Hmax = H
	Else
		Hmin = H
	H = (Hmin + Hmax) / 2
	oModelPar.Value = H
	oDoc.Update
	V = oMassProps.Volume
	ThisApplication.activeview.update
Loop
oDoc.Update
oPars.Item("Current_Volume").Value = V
Dim delta As Double = Math.Abs(V - Target_Volume)/Target_Volume
'report
MsgBox ("N = " & N & vbNewLine & "V = " & _
       oUOM.GetStringFromValue(V, "l") & vbNewLine & _
      "Delta = " & delta)
Updated version of your part is attached.
Hope this rule is a good start point to move further.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Valued Contributor
fakeru
Message 16 of 16 (88 Views)
10-17-2012 12:43 AM in reply to: Vladimir.Ananyev
This rule looks very good. I think it is just what I need. Probably I will have to tweak it a little bit, as it will run for a multibody part. Hope it will work.
Thank you very much Vladimir!
Spasibo!:smileyhappy:
AIP 2014
Windows 7 x64
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
