I am trying to create a form, so that my designers can pick their parameters when they first start a new part.
For this form I have created a multi-valued parameter for them to select from.
My issue is, why does Inventor not list fractions in the correct order.
What I would like to see:
1/8"
3/16"
1/4"
5/16"
3/8"
7/16"
1/2"
9/16"
5/8"
11/16"
3/4"
13/16"
7/8"
15/16"
1"
What Inventor lists:
1"
1/2"
1/4"
11/16"
13/16"
15/16"
3/8"
3/16"
5/8"
5/16"
7/8"
7/16"
9/16"
Is there a way to get Inventor to list these parameters in order of value?
Thanks in advance,
Randall
I second this question. Inventor is ordering the numbers according to the digit values, not actual whole values. This makes no sense when you use the parameter on a form and get a radio button list that jumps from 1 to 10, then back down to 2. Any ideas on changing this?
I know this was a while ago, I was having the same problem in version 2014.
I added this illogic rule to my part.
MultiValue.SetList("Size", "1/8""", "3/16""", "1/4""", "5/16""", "3/8""", "7/16""", "1/2""", "9/16""", "5/8""", "11/16""", "3/4""", "13/16""", "7/8""", "15/16""", "1""")
It works, seems to force the Parameter's (named "Size") Multi-Value list to list as listed in the code.
Can this be done without illogic?
