Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Mirror 2d Sketch entity
3 REPLIES 3
578 Views, 3 Replies
Hello guys,
I would like to ask the following question:
How can you use the mirror feature in a sketch using Inventor VBA?
Although I am able to mirror a part feature (e.g. an extrude or a hole), I am not able to mirror -for example- a line within a sketch.
Thank you for your time,
3 REPLIES 3
xiaodong_liang
Unfortunately there isn’'t a direct way to mirror sketch objects. We have a wish #1286344.
You would need to calculate the 2d reflection matrix coefficients by an algorithm of your own and use method such as “Matrix2d.PutMatrixData” to fill up an Inventor Matrix2d. You can then use it to transform the required inputs to create a new mirrored sketch entity, e.g. mirror start/end points of the line, center/start/end of the arcs…
You can easily find documentation about reflection matrices on the web. Here are some examples, do not take it as references:
http://planetmath.org/encyclopedia/DerivationOf2DReflectionMatrix.html
http://en.wikipedia.org/wiki/Transformation_matrix
in reply to: xiaodong_liang
Thank you very much for your answer!
J.Pelfrene
Having exactly the same question. Any solution or workaround in the meantime?
Cheers!
