Hello All,
Could someone please explain to me why I would be getting a Method arguments must be enclosed in parentheses error on the following line of code
Component.InventorComponent("00000-H-A00-P-001_Handrail 48.3x3.2 CHS:1").BOMStructure = BOMStructureEnum.kDefaultBOMStructure
What do I need to do to fix it?
Your help is much appreciated
Kind Regards
Tim
Solved by tim.mulder. Go to Solution.
Thanks for your reply Luke,
It was a copy & paste from another forum post.
I did re-type the code as I know copying & pasting can cause issues.
Don't ask me why but I re-typed the code again for a 3rd time & it worked <Bangs head against Wall>
Thank you for your help though
Kind Regards
Tim
