Inventor Customization
dm1
Member
Message 1 of 3 (49 Views)
Max. file size
49 Views, 2 Replies
12-08-2003 11:42 PM
Does anyone know if there is a maximun file size the Iv can
hanle? I once and a while try to input a 45+ meg step file
from another cad program and the computer will not handle it. Is this a computer problem or software limits? Getting a new box but need to know what will handle this size of file.
Gerry
*Keller, Kent
Message 2 of 3 (49 Views)
Re: Max. file size
12-09-2003 01:20 AM in reply to: dm1
You would probably get more answers if you asked in the newsgroup for the version of
Inventor you are using. This group is for VBA and customization. Below are links to the
other groups.
When you import a step file I believe it has to do a lot of computations to bring the file
in. So if you look at the actual memory footprint of Inventor it is going to be a lot
bigger than the size of the file. MDT seems to do a little better job of brining in step
files and once you get it in there, you can stitch it and save it as a sat file that
Inventor can work with.
INVENTOR 7
Web
http://discussion.autodesk.com/WebX?14@249.WrzWaFipp7M.6@.f1591b5
Newsreader
news://discussion.autodesk.com/autodesk.inventor.7
INVENTOR 6
Web
http://discussion.autodesk.com/WebX?14@227.5Oz5aB0Toew.0@.f11e012
Newsreader
news://discussion.autodesk.com/autodesk.inventor.6
INVENTOR 5.3
Web
http://discussion.autodesk.com/WebX?14@227.5Oz5aB0Toew.0@.f11e011
Newsreader
news://discussion.autodesk.com/autodesk.inventor.5.3
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"dm1" wrote in message news:f1a4acf.-1@WebX.maYIadrTaRb...
> Thanks
> Gerry
dm1
Member
Message 3 of 3 (49 Views)
Re:
12-09-2003 02:51 AM in reply to: dm1
Will do; thanks
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
