Hey
Quick question, is there a way to make a drawing view precise before printing? I have a batch printer setup and it will print views that have the green box around them in which they print blurry. I can't seem to find the command (if it even exists)?
Solved by cadmanagershat. Go to Solution.
Could you check DrawingView.IsRasterView property value before printing?
This is a read-write property that gets and sets whether the drawing view is raster view or not.
Cheers,
Right now you can update a raster view to a precise view with the Inventor Task Scheduler. Wouldn't that be a nice task to add to the Vault task sheduler so you can be sure that if you release a drawing it's the way you want it? Then you don't have to worry printing a raster view?
David
I've been using this for the very same purpose.
I have to admit I'm yet to see the benefit of the Raster view!
For Each sheet As Sheet In ThisDrawing.Document.Sheets If sheet.DrawingViews.Count > 0 Then For Each view As DrawingView In sheet.DrawingViews view.IsRasterView = False Next End If Next
