Hi guys,
I want to put an engineering note to any machined surface of my part (IPT) so when I will create a drawing (IDW), it will appeare a leader note.
Is it possible to do that by Add-in?
Another way is to put a texture to any machined surface of my part (IPT) so when I will create a drawing (IDW), it will appeare a leader note indicating a machined surface.
Anybody could help me?
Hi Raminasrl,
Engineering notes cannot be created from API. You could attach an attribute to your Face and use that from API to generate leader notes.
Take a look at "Custom Data/Working with Attributes" in the API Help Files.
Here is a sample from the help files that illustrates how to create a leader note:
Public Sub AddLeaderNote() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oActiveSheet As Sheet Set oActiveSheet = oDrawDoc.ActiveSheet ' Set a reference to the drawing curve segment. ' This assumes that a drawing curve is selected. Dim oDrawingCurveSegment As DrawingCurveSegment Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1) ' Set a reference to the drawing curve. Dim oDrawingCurve As DrawingCurve Set oDrawingCurve = oDrawingCurveSegment.Parent ' Get the mid point of the selected curve ' assuming that the selected curve is linear Dim oMidPoint As Point2d Set oMidPoint = oDrawingCurve.MidPoint ' Set a reference to the TransientGeometry object. Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry Dim oLeaderPoints As ObjectCollection Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection ' Create a few leader points. Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10)) Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5)) ' Create an intent and add to the leader points collection. ' This is the geometry that the leader text will attach to. Dim oGeometryIntent As GeometryIntent Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve) Call oLeaderPoints.Add(oGeometryIntent) ' Create text with simple string as input. Since this doesn't use ' any text overrides, it will default to the active text style. Dim sText As String sText = "API Leader Note" Dim oLeaderNote As LeaderNote Set oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText) ' Insert a node. Dim oFirstNode As LeaderNode Set oFirstNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1) Dim oSecondNode As LeaderNode Set oSecondNode = oFirstNode.ChildNodes.Item(1) Call oFirstNode.InsertNode(oSecondNode, oTG.CreatePoint2d(oMidPoint.X + 5, oMidPoint.Y + 5)) End Sub
Hope this helps,
Philippe.
How can I find all oDrawingCurve in the drawing from face in the model?
Thanks for any help.
Parent Object: DrawingView
Property that returns all the drawing curves within the drawing view optionally filtered to the input model object. This property returns Nothing for draft views.iew object represents a drawing view on a sheet.
DrawingView.DrawingCurves( [ModelObject] As Variant ) As DrawingCurvesEnumerator
Name | Description |
ModelObject | Optional input object that specifies the object from the model for which the corresponding drawing view curves need to be retrieved. This could be an Edge, Face, PartFeature, Sketch, SketchEntity, Sketch3D, SketchEntity3D, ComponentOccurrence, or the proxies to any of these. If not specified, all the edges from the drawing view are returned. |
Sweet, please flag as solved (and give kudos ;))
Philippe.
