hello
im new in inventor and new in ilogic.
i looking for a script, that "save as" my top assembly and...
- delete all features of the parts in my assembly, that are disable like this
Feature.IsActive("Hole1") = False
Feature.IsActive("Radius1") = False
- delete all rules and formulars in all assemblys and parts
- delete all custom parameters in the top assembly
so that i ve after run the "save as"-script, a clean assembly....
perhaps anyone of you have something like this
regard
You may consider something like this:
ThisDoc.Document.SaveAs(NewFileNameAndExtension, True) 'Delete suppressed features in components at all levels Dim oAsmDoc As AssemblyDocument = ThisDoc.Document For Each oDoc As Inventor.Document In oAsmDoc.AllReferencedDocuments If TypeOf oDoc Is PartDocument Then Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition For Each oFeature As PartFeature In oDef.features If oFeature.Suppressed Then oFeature.Delete Next End If Next Beep InventorVb.DocumentUpdate()
Hope this helps.
