I have an iLogic rule that converts certain dimensions from a fractional dimension to a sheet steel gage. It is looping through all the General Dimensions on the drawing. This causes some of my angular dimensions to be updated by mistake, so I need it to exclude all angular dimensions when it runs through the loop and can't find how to do it.
The code is given below if that is of any assistance.
Dim oDoc as DrawingDocument Dim tDim as String oDoc = ThisApplication.ActiveDocument Dim sheetX As Sheet = oDoc.Sheets(1) For Each genDim as GeneralDimension In sheetX.DrawingDimensions.GeneralDimensions tDim = gendim.text.formattedtext If (Len(tDim) > 25) Then Goto 30: gendim.hidevalue = False genFrac = (RoundToFraction(genDim.modelvalue/2.54,1/64,RoundingMethod.Round)) If (genFrac = "3/16" Or genFrac = "1/8" Or genFrac = "1/16" Or genFrac = "3/64") Then If (Right(iProperties.Value("Custom","Material Thickness"),3) = "ga.") Then genDim.hidevalue = True gendim.text.formattedtext = iProperties.Value("Custom","Material Thickness") Else gendim.text.formattedtext = "" End If End If 30: Next
Dan
Here you can find a piece of code I use to look for angular an linear dimensions and center them. It can be useful for you as an example where linear and angular dimensions are identified. You can use it to modify only the linear dimensions.
SyntaxEditor Code Snippet
'Centre and arrange dimensions Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDoc.ActiveSheet Dim oDrawingDim As DrawingDimension Dim oDrawingDims As DrawingDimensions Dim oDimsToBeArranged As ObjectCollection Dim iLinearDimCount As Integer Dim iAngularDimCount As Integer Dim iOtherDimCount As Integer iLinearDimCount = 0 iAngularDimCount = 0 iOtherDimCount = 0 ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. ' Add them to the ObjectCollection to be arranged oDrawingDimensions = oSheet.DrawingDimensions oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection For Each oDrawingDim In oDrawingDimensions Select Case oDrawingDim.Type Case 117474560 ' kLinearGeneralDimensionObject oDrawingDim.CenterText oDimsToBeArranged.Add(oDrawingDim) iLinearDimCount = iLinearDimCount+1 Case 117474816 'kAngularGeneralDimensionObject oDrawingDim.CenterText oDimsToBeArranged.Add(oDrawingDim) iAngularDimCount = iAngularDimCount+1 Case Else iOtherDimCount = iOtherDimCount +1 End Select Next Trace.Writeline("Linear dimensions = "& iLinearDimCount) Trace.Writeline("Angular dimensions = "& iAngularDimCount) Trace.Writeline("Other dimensions = "& iOtherDimCount) oDrawingDimensions.Arrange(oDimsToBeArranged)
