Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Isolating Dimension Type using iLogic
2 REPLIES 2
djbrown
635 Views, 2 Replies
I have an iLogic rule that converts certain dimensions from a fractional dimension to a sheet steel gage.  It is looping through all the General Dimensions on the drawing.  This causes some of my angular dimensions to be updated by mistake, so I need it to exclude all angular dimensions when it runs through the loop and can't find how to do it.
The code is given below if that is of any assistance.
Dim oDoc as DrawingDocument
Dim tDim as String
oDoc = ThisApplication.ActiveDocument
Dim sheetX As Sheet = oDoc.Sheets(1)
For Each genDim as GeneralDimension In sheetX.DrawingDimensions.GeneralDimensions
   tDim = gendim.text.formattedtext
   If (Len(tDim) > 25) Then Goto 30:
   gendim.hidevalue = False
   genFrac = (RoundToFraction(genDim.modelvalue/2.54,1/64,RoundingMethod.Round))
   If (genFrac = "3/16" Or genFrac = "1/8" Or genFrac = "1/16" Or genFrac = "3/64") Then
      If (Right(iProperties.Value("Custom","Material Thickness"),3) = "ga.") Then
         genDim.hidevalue = True
	     gendim.text.formattedtext = iProperties.Value("Custom","Material Thickness")
	  Else
	     gendim.text.formattedtext = ""
	  End If
   End If
30: Next
Dan
2 REPLIES 2
RodrigoEiras
in reply to: djbrown
Here you can find a piece of code I use to look for angular an linear dimensions and center them. It can be useful for you as an example where linear and angular dimensions are identified. You can use it to modify only the linear dimensions.
SyntaxEditor Code Snippet
'Centre and arrange dimensions
    Dim oDoc As DrawingDocument
     Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim oDrawingDim As DrawingDimension
    Dim oDrawingDims As DrawingDimensions
    Dim oDimsToBeArranged As ObjectCollection
    Dim iLinearDimCount As Integer
    Dim iAngularDimCount As Integer
    Dim iOtherDimCount As Integer
    iLinearDimCount = 0
    iAngularDimCount = 0
    iOtherDimCount = 0
    ' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
    ' Add them to the ObjectCollection to be arranged
    oDrawingDimensions = oSheet.DrawingDimensions
    oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection
    For Each oDrawingDim In oDrawingDimensions
        Select Case oDrawingDim.Type
            Case 117474560    ' kLinearGeneralDimensionObject
                oDrawingDim.CenterText
                   oDimsToBeArranged.Add(oDrawingDim)
                iLinearDimCount = iLinearDimCount+1
            Case 117474816 'kAngularGeneralDimensionObject
                iAngularDimCount = iAngularDimCount+1
            Case Else
                iOtherDimCount = iOtherDimCount +1
        End Select
    Next
    Trace.Writeline("Linear dimensions = "& iLinearDimCount)
    Trace.Writeline("Angular dimensions = "& iAngularDimCount)
    Trace.Writeline("Other dimensions = "& iOtherDimCount)
    oDrawingDimensions.Arrange(oDimsToBeArranged)
holethreadnote = 72194
