Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Is there a way to target .net 4 for an Inventor 2012 add-in?
3 REPLIES 3
665 Views, 3 Replies
We have a large code base that is migrated to .net 4. I did not find an easy way to target .net 4 when writing an add-in for Inventor 2012.
Is there a solution to this?
Tags (3)
3 REPLIES 3
FarrenYoung
It seems like I was able to do this once using a "registry-based" addin.  I know it's a step back since we're told to use "registry-free" addins in Inventor 2012 foward, but I think this works.  Can you try that and let us know?
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
in reply to: FarrenYoung
Thank you for this idea, maybe someone from Adesk can chime in and confirm if this is a possibility in theory?
My gut feeling tells me that the problem with the Adesk 3.5 file needing to reference my 4.0 dlls might remain.
adam.nagy
Hi Johan,
Yes, what Farren said seems to work. I assume because of the Side by Side execution feature of .NET 4: http://blogs.microsoft.co.il/blogs/arik/archive/2011/05/30/how-to-use-a-net-4-based-dll-from-net-2-b...
Actually, I thought that the Reg-Free version could work as well, but I did not manage to achieve that.
Another thing you can do is force Inventor to use the .NET 4 Framework. This seems to work fine, but still it is unsupported, so if you run into any problems with it then we cannot help.
In order to do that you need to make sure that the <startup></startup> section of Inventor.exe.config has the following:
  <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntimeversion="v4.0"/>
  </startup
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
