Passi,
Did you ever find a solution to this? I was searching for this issue and came across your post.
Randy
no, or at least not until now 🙂
I asked Autodesk via Subscription Support request and this was the answer:
No, you cannot define the position of the iLogic form, it will always appear in the
last used position. You can resize the form during runtime by RMB in the form.
You cannot control the position.
So, it seems to be not possible to change the position. And what it means: "It will appear in the last used position", I cannot tell. Because I can move the dialog across the screen and it will never remember it's position.
Autodesk put my question into the discussion group but also with no result.
If you may discover something, please let me know.
All you can do otherwise is to put it into an normal iLogic form and fix the position by putting it in the area of the inventor browser. Then it's always at that position. But for my use it's not enough.
Best Regards
Passi
Apparently this is still a problem. I just had Inventor 2015 reloaded on my machine and my iLogic form ALWAYS comes in on top of the main browser. Wasn't like this in the previous load. I always have to drag it out and reposition. To the point response from Autodesk, it does not remember or retain its previous position.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I would assume this is as designed.
The point of the iLogic stuff is to provide quick, easy access to things for beginners.
If you want to control the position of it, make a WPF and set the options in there, then import the .dll you create with it for use in a rule.
Good Luck!
