Can I create popup button control underneath another poup button control?
I can do this with .net controls, but I can't seem to get this to work with Inventor. Whenever I try to add a commandbar to another commandbar.Controls I get an Invalid Parameter error.
Here is what I am referring to. I would like to be able to add a menu below a menu.
Solved by FarrenYoung. Go to Solution.
In theory, I think LinearMenu.AddButtonPopup or LinearMenu.AddPopup should work, however they both failed at my side. I am digging if I could figure it out.
Have you been able to figure this out yet?
In case anyone has this question, I received word via ADN that this is not possible.
Is this still an issue with Inventor 2016, 2017 & 2018 API?
I used code which added a command bar as a popup menu to the context menu in Inventor 2012, however as I am upgrading our in house applications to Inventor 2016, I am finding I cannot replicate this functionality in the Linear Marking Menu?
Many Thanks
