In the Iproperties project tab I would like to change the "Stock Number" name to "A.R.M.-PN:". I need to reference 2 part numbers in my IPT Iproperties. This will then show up on the Parts List as a column which I can add. Or I would like to add a new dialog box to the "Project Tab". Is there a easy way to do this in 2011 Inventor Professional?
Aaron J. Potts "Pottsy"
Metal Artist/Mechanical Designer
Built By Pottsy LLC
You can combine two part numbers into a iProperty a few diffrent ways
With iLogic it's a little less likely that the new stock number will be overidden. The example below shows you the basic format. You can pull PartNumber1 and PartNumber2 from where you need to, even other iProperties as shown. Remember to place an event trigger on the iLogic rule like "Before Save Document"
PartNumber1 = iProperties.Value("Project", "Part Number") PartNumber2 = iProperties.Value("Project", "Stock Number") iProperties.Value("Custom", "A.R.M.-PN:") = PartNumber1 & " : " & PartNumber2
You can also put something like this directly into the iProperty - though it can be overidden.
Notice the "=" before the variables. That starts the formula in the iProperty field. See the attached screenshot.
=<Part Number> : <Stock Number>
Hope that helps!
Ok.... Cool.. I Think That Will Get Me Where I Need To Be...!
Us Carroll County Boys Are A Little Slow Be We Catch On Fast.. 🙂
Pottsy
Ok, I am back on this again. Check out the attached picture. I would like to change the names in the Iproperties and the save that as a template part. Can this be done easily?
As far as I know you can't change a standard iProperty name like you are wanting, but you can decide what gets written in the input field.
You are better off just creating custom iProperties with those names and then outputting that information to the orginal iProperty fields that you need.
