Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor macro – Export workpoints to CSV file inside assembly
5 REPLIES 5
hreuvers
1236 Views, 5 Replies
Macro's for IPT support are commonly available, here a modified version with (multi-level) assembly support.
- XYZ coordinates of work points relative to origin of main assembly will be exported to a CSV file
- Works with parts in sub-assemblies and in sub-sub-assemblies (3 levels)
- Work points inside suppressed parts/ assemblies are excluded
- Visibility state of work point will be ignored (non-visible work points will be exported)
- Filter work points with (partial) name of the work point (e.g. “center” for “Center Point”)
See attachments for more information...
5 REPLIES 5
adam.nagy
in reply to: hreuvers
I'm just trying to make sure I'm not misunderstaning somthing 🙂
You simply uploaded this as a sample or are you having some issues you need help with?
Cheers,
Adam Nagy
Autodesk Platform Services
hreuvers
in reply to: adam.nagy
It is a full working macro with an example!
Because I used some routines from other sources,
I would like to share this with others too!
Just giving back to the communitySmiley Happy
Dude!  I know this is an old thread, but thanks for taking the time to upload your util - you saved me a metric binload of time.  I couldn't believe my luck finding this, it was exactly what I was looking for.  Like you, I had found a bunch of examples extracting from a part level but the assy level is what the fans want.
mneesley
ErmaGERD this is unbelievably AWESOME 🙂
emurphySMV59
I am getting "Run-time error '-2147467259 (80004005)': Method 'Definition' of object 'ComponentOccurence' failed. Any idea what is going on? Thanks
