I have written the following code for my inventor addin. Everything works fine (or so it seems), but I am stuck with a problem that I cannot make sense of.
So far my code creates a new ribbon panel and button on the tools tab for parts, assemblies, zerodoc & drawings.
I have created a dialog that I want to open from this button. However since I have created a wrapper to make my dialog modeless, I am not sure how to pass the "inventor.application" variable to my new dialog so that I can process futher.
Any tips / ideas will be most welcome.
The code is quite long, but the area where I think I need to make changes is "PrivateSub m_buttonDef_OnExecute(ByVal Context As Inventor.NameValueM...."
Imports Inventor Imports System.Runtime.InteropServices Imports Microsoft.Win32 Namespace VMUtils <ProgIdAttribute("VMUtils.StandardAddInServer"), _ GuidAttribute("4b0c909e-4a1f-435a-a37f-63ab230e1dc6"), _ ComVisible(True)> _ Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer ' Inventor application object. Shared m_inventorApplication As Inventor.Application '################################################################################################# '# BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # '# --------------------------------------------------------------------------------------------- # '# Class wide variable declerations # '# # '################################################################################################# Private m_clientID As String Private WithEvents m_iprop_buttonDef As ButtonDefinition = Nothing Private WithEvents m_uiEvents As UserInterfaceEvents = Nothing '################################################################################################# '# END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # '# --------------------------------------------------------------------------------------------- # '# Class wide variable declerations # '# # '################################################################################################# #Region "ApplicationAddInServer Members" Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, _ ByVal firstTime As Boolean) _ Implements Inventor.ApplicationAddInServer.Activate ' This method is called by Inventor when it loads the AddIn. ' The AddInSiteObject provides access to the Inventor Application object. ' The FirstTime flag indicates if the AddIn is loaded for the first time. ' Initialize AddIn members. m_inventorApplication = addInSiteObject.Application '################################################################################################# '# BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # '# --------------------------------------------------------------------------------------------- # '# My code # '# # '################################################################################################# m_clientID = AddInGuID(GetType(StandardAddInServer)) If firstTime Then CreateUserInterface() End If m_uiEvents = m_inventorApplication.UserInterfaceManager.UserInterfaceEvents '################################################################################################# '# END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # '# --------------------------------------------------------------------------------------------- # '# My code # '# # '################################################################################################# ' TODO: Add ApplicationAddInServer.Activate implementation. ' e.g. event initialization, command creation etc. End Sub Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate ' This method is called by Inventor when the AddIn is unloaded. ' The AddIn will be unloaded either manually by the user or ' when the Inventor session is terminated. ' TODO: Add ApplicationAddInServer.Deactivate implementation ' Release objects. Marshal.ReleaseComObject(m_inventorApplication) m_inventorApplication = Nothing System.GC.WaitForPendingFinalizers() System.GC.Collect() End Sub Public ReadOnly Property Automation() As Object Implements _ Inventor.ApplicationAddInServer.Automation ' This property is provided to allow the AddIn to expose an API ' of its own to other programs. Typically, this would be done by ' implementing the AddIn's API interface in a class and returning ' that class object through this property. Get Return Nothing End Get End Property Public Sub ExecuteCommand(ByVal commandID As Integer) Implements _ Inventor.ApplicationAddInServer.ExecuteCommand ' Note:this method is now obsolete, you should use the ' ControlDefinition functionality for implementing commands. End Sub #Region "Property definitions" '################################################################################################# '# BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # '# --------------------------------------------------------------------------------------------- # '# My property definitions # '# # '################################################################################################# 'This property use reflection to get the value for the GuIDAttribute of the attached class Public Shared ReadOnly Property AddInGuID(ByVal t As Type) As String Get Dim guid As String = "" Try Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False) Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute) guid = "{" + guidAttribute.Value.ToString() + "}" Finally AddInGuID = guid End Try End Get End Property '################################################################################################# '# END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # '# --------------------------------------------------------------------------------------------- # '# My property definitions # '# # '################################################################################################# #End Region #Region "Custom methods" '################################################################################################# '# BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # BEGIN # '# --------------------------------------------------------------------------------------------- # '# Custom Methods # '# # '################################################################################################# Public Sub CreateUserInterface() 'Get a reference to the UserinterfaceManager Object '--------------------------------------------- Dim UIManager As Inventor.UserInterfaceManager = m_inventorApplication.UserInterfaceManager Dim controlDefs As ControlDefinitions = m_inventorApplication.CommandManager.ControlDefinitions Dim small_I_Prop_Icon As stdole.IPictureDisp = PictureConverter.ImageToPictureDisp _ (My.Resources.IPIcon16X16) Dim lrg_I_Prop_Icon As stdole.IPictureDisp = PictureConverter.ImageToPictureDisp _ (My.Resources.IPIcon32X32) Dim toolPanelDispname As String = "Viz-Mec tools" Dim parttoolPanelInternalName As String = "partVMTools" Dim assytoolPanelInternalName As String = "assyVMTools" Dim drawtoolPanelInternalName As String = "drawVMTools" Dim zerotoolPanelInternalName As String = "zeroVMTools" Dim partDocRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("Part") Dim drawingDocRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("Drawing") Dim assyDocRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("Assembly") Dim zeroDocRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("ZeroDoc") Dim partDocToolsTab As Inventor.RibbonTab = partDocRibbon.RibbonTabs.Item("id_TabTools") Dim assyDocToolsTab As Inventor.RibbonTab = assyDocRibbon.RibbonTabs.Item("id_TabTools") Dim drawDocToolsTab As Inventor.RibbonTab = drawingDocRibbon.RibbonTabs.Item("id_TabTools") Dim zeroDocToolsTab As Inventor.RibbonTab = zeroDocRibbon.RibbonTabs.Item("id_TabTools") Dim partdocToolPanel As Inventor.RibbonPanel Dim assydocToolPanel As Inventor.RibbonPanel Dim drawdocToolPanel As Inventor.RibbonPanel Dim zerodocToolPanel As Inventor.RibbonPanel partdocToolPanel = partDocToolsTab.RibbonPanels.Add(toolPanelDispname, _ parttoolPanelInternalName, m_clientID) assydocToolPanel = assyDocToolsTab.RibbonPanels.Add(toolPanelDispname, _ assytoolPanelInternalName, m_clientID) drawdocToolPanel = drawDocToolsTab.RibbonPanels.Add(toolPanelDispname, _ drawtoolPanelInternalName, m_clientID) zerodocToolPanel = zeroDocToolsTab.RibbonPanels.Add(toolPanelDispname, _ zerotoolPanelInternalName, m_clientID) m_iprop_buttonDef = controlDefs.AddButtonDefinition("Iprops", "vmUtilsIProps", _ CommandTypesEnum.kNonShapeEditCmdType, _ m_clientID, _ , _ , _ small_I_Prop_Icon, _ lrg_I_Prop_Icon) partdocToolPanel.CommandControls.AddButton(m_iprop_buttonDef, True) assydocToolPanel.CommandControls.AddButton(m_iprop_buttonDef, True) drawdocToolPanel.CommandControls.AddButton(m_iprop_buttonDef, True) zerodocToolPanel.CommandControls.AddButton(m_iprop_buttonDef, True) End Sub '################################################################################################# '# END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # END # '# --------------------------------------------------------------------------------------------- # '# Custom Methods # '# # '################################################################################################# #End Region #End Region Private Sub m_buttonDef_OnExecute(ByVal Context As Inventor.NameValueMap) _ Handles m_iprop_buttonDef.OnExecute Dim Ipropfrm As frmiProps = New frmiProps Ipropfrm.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND)) End Sub End Class <System.ComponentModel.DesignerCategory("")> Friend Class PictureConverter Inherits System.Windows.Forms.AxHost Private Sub New() MyBase.New(String.Empty) End Sub Public Shared Function ImageToPictureDisp(ByVal image As System.Drawing.Image) As _ stdole.IPictureDisp Return CType(GetIPictureDispFromPicture(image), stdole.IPictureDisp) End Function End Class #Region "hWnd Wrapper Class" ' This class is used to wrap a Win32 hWnd as a .Net IWind32Window class. ' This is used for parenting a dialog to the Inventor window. ' ' For example: ' ' myForm.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND)) ' Public Class WindowWrapper Implements System.Windows.Forms.IWin32Window Public Sub New(ByVal handle As IntPtr) _hwnd = handle End Sub Public ReadOnly Property Handle As System.IntPtr Implements System.Windows.Forms.IWin32Window.Handle Get Return _hwnd End Get End Property Private _hwnd As IntPtr End Class #End Region End Namespace
Dim Ipropfrm As frmiProps = New frmiProps Dim owner As New Windows.Forms.NativeWindow owner.AssignHandle(m_inventorApplication.MainFrameHWND) Ipropfrm.Show(owner)
This will open the form under inventor
