Inventor Customization
Valued Contributor
dano0310
Message 11 of 18 (778 Views)
Re: Inventor VBA xls export
11-07-2012 03:33 PM in reply to: varga_zsolt
Try This it should get you somewhere near where you need to be.
Sub BOM_Export()
    Dim oApp As Application
    Set oApp = ThisApplication
    If oApp.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
        Dim oAssyDoc As AssemblyDocument
        Set oAssyDoc = oApp.ActiveDocument
        Dim oAssyCompDef As AssemblyComponentDefinition
        Set oAssyCompDef = oAssyDoc.ComponentDefinition
        Dim excel_app As Excel.Application
        ' Create the Excel application.
        Set excel_app = CreateObject("Excel.Application")
        ' Uncomment this line to make Excel visible.
        excel_app.Visible = True
        'Create new workbook
        Call excel_app.Workbooks.Add
        Dim oBomR As BOMRow
        Dim oBOMPartNo As String
        With excel_app
            .Range("A1").Select
            .ActiveCell.Value = "Quantity"
            .Range("B1").Select
            .ActiveCell.Value = "Part Number"
            'Iterate through parts only BOM View
            Dim i As Integer
            For i = 1 To oAssyCompDef.BOM.BOMViews(3).BOMRows.Count
                'Set oBomR to current BOM Row
                Set oBomR = oAssyCompDef.BOM.BOMViews(3).BOMRows(i)
                'Get Current Row part number from part
                oBOMPartNo = oBomR.ComponentDefinitions(1).Document.PropertySets(3).ItemByPropId(5).Value
                'Write values to spreadsheet
                .Range("A" & i + 1).Select
                .ActiveCell.Value = oBomR.TotalQuantity 'Quantity value
                .Range("B" & i + 1).Select
                .ActiveCell.Value = oBOMPartNo
            Next i
        End With
    Else
        Exit Sub
    End If
End Sub
Dont forget toset your reference to excel in the VBA.  Basically go to "Tools", "References" then look for "Microsoft Excel 14.0 Object Library".  Without it this wont work.
Active Contributor
varga_zsolt
Message 12 of 18 (772 Views)
11-07-2012 11:14 PM in reply to: dano0310
Thank you dano0310, i try this code but there is error and i donn't konw what is the problem.
Active Contributor
varga_zsolt
Message 13 of 18 (765 Views)
11-07-2012 11:55 PM in reply to: varga_zsolt
For precision i need this: i need the file like the csv attached, in the R column i need the date of the day whan i lunch the vba code :-D and i need to save the file in the folder where the *.iam is saved with the same name of the *.iam file but in *.csv separated by coma.
Active Contributor
varga_zsolt
Message 14 of 18 (726 Views)
11-16-2012 05:24 AM in reply to: dano0310
Please can someone help me :smileysad:
ADN Support Specialist
adam.nagy
Message 15 of 18 (702 Views)
11-21-2012 06:06 AM in reply to: varga_zsolt
Hi Zsolt,
Two things:
1) I cannot see the csv file you mention attached anywhere
2) The errer.jpg that is supposed to show the error you've run into does not actually show any error. It simply shows the line that VBA is about to execute, so it gives no clue about what problem you are running into
Also, it might be worth first just printing everything into the "Immediate" window of VBA to see what is going on.
E.g. :
Sub ListRows(brs As BOMRowsEnumerator)
    Dim br As BOMRow
    For Each br In brs
        Debug.Print br.ItemNumber & ", " & br.ItemQuantity
        If Not br.ChildRows Is Nothing Then
            Call ListRows(br.ChildRows)
        End If
    Next
End Sub
Sub test()
    Dim ad As AssemblyDocument
    Set ad = ThisApplication.ActiveDocument
    Dim acd As AssemblyComponentDefinition
    Set acd = ad.ComponentDefinition
    Dim bom As bom
    Set bom = acd.bom
    ' Depending on what you need
    bom.StructuredViewEnabled = True
    bom.StructuredViewFirstLevelOnly = False
    ' Structured BOM view is second if it's enabled
    Dim bv As BOMView
    Set bv = bom.BOMViews(2)
    ' Header
    Debug.Print "Item Number, Quantity"
    ' Data
    Call ListRows(bv.BOMRows)
End Sub
Cheers,
Adam Nagy
Developer Technical Services
Autodesk Developer Network
Active Contributor
varga_zsolt
Message 16 of 18 (696 Views)
11-21-2012 06:29 AM in reply to: adam.nagy
1- Scuse me but i can't attach the *.csv file in this forum.
2 - The vba code give me the error you can see in the attached jpg.
Active Contributor
varga_zsolt
Message 17 of 18 (678 Views)
11-26-2012 12:50 AM in reply to: dano0310
This is the line who gives me the error:
Active Contributor
varga_zsolt
Message 18 of 18 (673 Views)
11-26-2012 06:23 AM in reply to: dano0310
I heve find a solution!! :smileytongue:
Sub BOM_Export()
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    Dim oDocument As Inventor.Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim invDesignInfo As PropertySet
    Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
    Dim invPartNumberProperty As Property
    Set invPartNumberProperty = invDesignInfo.Item("Part Number")
    NumeroParte = invPartNumberProperty.Value
    Estensione = (".csv")
    Patch = GetFilePatch(oDocument.FullFileName)
    PercaorsoNomeEst = (Patch & NumeroParte & Estensione)
    'Data
    Dim DataCmp As String
    DataCmp = (Day(Date) & "/" & Month(Date) & "/" & Year(Date))
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
     ' Imposta corrente il livello Principale
    Dim oAsmDef As AssemblyComponentDefinition
    Set oAsmDef = ThisApplication.ActiveDocument.ComponentDefinition
    oAsmDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Principale").Activate
        ' Setta la proprietà della vista strutturale al solo di primo livello
        oBOM.StructuredViewFirstLevelOnly = True
        ' Attiva la vista strutturata della distinata componenti
        oBOM.StructuredViewEnabled = True
        ' Crea l'applicazione Excel
        ' Commenta questa linea se vuoi excel invisibile
        excel_app.Visible = False
        'Crea il foglio di lavoro
        Dim oBomR As BOMRow
        With excel_app
            .Range("A1").Select
            .Range("B1").Select
            .Range("R1").Select
            .ActiveCell.Value = "Inizio Validità"
            Dim i As Integer
            For i = 1 To oAssyCompDef.BOM.BOMViews(2).BOMRows.Count
                Set oBomR = oAssyCompDef.BOM.BOMViews(2).BOMRows(i)
                .Range("R" & i + 1).Select
                .ActiveCell.Value = DataCmp
            Next i
        End With
    Else
        Exit Sub
    End If
    ActiveWorkbook.SaveAs filename:=(PercaorsoNomeEst), FileFormat:=xlCSVWindows, CreateBackup:=False, Local:=True
    Application.DisplayAlerts = False
    ActiveWorkbook.Close
    End
End Sub
'Funzione che estrae il percorso completo nel quale si trova il file attualmente in uso
Private Function GetFilePatch(ByVal sFullFileName As String) As String
  Dim sFilePatch As String
  Dim nPos1  As Integer
  Dim nPosf1 As Integer
  Dim nPos2 As Integer
  sFilePatch = sFullFileName
  nPos1 = InStrRev(sFullFileName, "\")
  nPos2 = InStrRev(sFullFileName, ".")
  If nPos1 > 0 Then
    sFilePacth = Mid$(sFullFileName, nPos1 + 1)
  End If
  nPosf1 = InStr(sFullFileName, ".")
  If nPos1 > 0 Then
    sFilePatch = Left$(sFilePatch, nPosf1 - (nPos2 - nPos1))
  End If
  GetFilePatch = sFilePatch
End Function
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
