Inventor Customization
Active Member
Message 1 of 5 (300 Views)
Accepted Solution
Inventor Template Customization
300 Views, 4 Replies
09-16-2012 04:28 AM
Dear Team,
I would like to make my template as per the requirement and want to lock some of the options or features for creating any kind of model.
Example : If my team is working on Sheet Metal module, then I want them to only check the Material Thickness, which I have defined in the Template, other features like Material Style & Unfold Rule must be locked.
Please help me ...
Thank you.
Nasrullah Baig Mirza,
Mechanical Design Engineer,
ADN Support Specialist
xiaodong.liang
Message 2 of 5 (268 Views)
Re: Inventor Template Customization
09-20-2012 08:43 PM in reply to: mirzanasrullah
I do not see a way to disable some settings. The only I can suggest is:
either your code could pop out a warning after the end user modifies the relevant options (such as rule). And ask him not to modify the rule.
or when the end user closes the document, pop out the warning to indicate the rule is modified and ask him to change back to the orignal.
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Active Member
Message 3 of 5 (251 Views)
09-24-2012 01:57 AM in reply to: xiaodong.liang
Dear Liang,
Thank you for the reply, which was helpful to me...
In the case which u explained, who can I make change for the Pop-up for the Team. Any hint which I can modify any script or registry.
Thank you.
xiaodong.liang
Message 4 of 5 (232 Views)
09-26-2012 08:09 PM in reply to: mirzanasrullah
Hi Mirza,
I meant to start some events such as ApplicationEvents.OnCloseDocument. In this event, check if the rule is changed. If yes, just pop out a message box to tell the user. And cancel the operation by HandlingCode = kEventCanceled . thus the closing will not proceed.
Xiaodong Liang
Active Member
Message 5 of 5 (211 Views)
09-30-2012 10:59 PM in reply to: xiaodong.liang
Thank you.... Very Much.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
