Is there a way to hook into the Inventor ribbon buttons (not custom) to monitor a click event?
What I would like to do is kick off a job to the job processor when a user checks a file into Vault. The job is for creating a DXF file of a sheet metal part. I'm not sure if launching a job when file is checked into vault is the right approach. Seems overkill but apparently DXF files are not getting produced. Open to other suggestions.
I came across an article on the Manufacturing DevBlog "Intercept click event on ribbon tab":
http://adndevblog.typepad.com/manufacturing/2013/02/intercept-click-event-on-a-ribbon-tab.html
The example code sets up an event listener to monitor the click event for the "Tools" tab. I modified the code to monitor the event for when the "Vault" tab (or id_TabVault) is clicked but for some reason the event handler is never triggered. The other tabs like "Tools" and "Getting Started" can trigger the event handler. See code below.
But even if I could get to the Vaults tab, how would I set up the event handler for the Check-In button? Is this possible?
using System; using System.Runtime.InteropServices; using System.Windows; using Autodesk.Windows; using Inventor; using Microsoft.Win32; using System.Diagnostics; namespace InventorCheckinAddIn { /// <summary> /// This is the primary AddIn Server class that implements the ApplicationAddInServer interface /// that all Inventor AddIns are required to implement. The communication between Inventor and /// the AddIn is via the methods on this interface. /// </summary> [GuidAttribute("30887386-a1a2-4b90-b497-316e2e3e995a")] public class StandardAddInServer : Inventor.ApplicationAddInServer { private Inventor.UserInterfaceEvents uiEvents; // Inventor application object. private Inventor.Application m_inventorApplication; public StandardAddInServer() { } #region ApplicationAddInServer Members public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime) { // This method is called by Inventor when it loads the addin. // The AddInSiteObject provides access to the Inventor Application object. // The FirstTime flag indicates if the addin is loaded for the first time. // Initialize AddIn members. m_inventorApplication = addInSiteObject.Application; //delegate the event when the ribbon is initialized Autodesk.Windows.ComponentManager.ItemInitialized += new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized); } void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e) { //now one Ribbon item is initialized, but the Ribbon control //may not be available yet, so check before if (Autodesk.Windows.ComponentManager.Ribbon != null) { foreach (Autodesk.Windows.RibbonTab Tab in Autodesk.Windows.ComponentManager.Ribbon.Tabs) { if (Tab.Id == "id_TabVault" || Tab.Id == "id_GetStarted" || Tab.Id == "id_TabTools") { Tab.Activated += new EventHandler(Tab_Activated); } } //and remove the event handler Autodesk.Windows.ComponentManager.ItemInitialized -= new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized); } } // when the tab is activated void Tab_Activated(object sender, EventArgs e) { // *** THE Tab_Activated NEVER SEES THE VAULT TAB CLICK EVENT *** System.Windows.Forms.MessageBox.Show( "Tab " + ComponentManager.Ribbon.ActiveTab.Id + " Activated!"); } public void Deactivate() { // This method is called by Inventor when the AddIn is unloaded. // The AddIn will be unloaded either manually by the user or // when the Inventor session is terminated // TODO: Add ApplicationAddInServer.Deactivate implementation // Release objects. Marshal.ReleaseComObject(m_inventorApplication); m_inventorApplication = null; GC.WaitForPendingFinalizers(); GC.Collect(); } public void ExecuteCommand(int commandID) { // Note:this method is now obsolete, you should use the // ControlDefinition functionality for implementing commands. } public object Automation { // This property is provided to allow the AddIn to expose an API // of its own to other programs. Typically, this would be done by // implementing the AddIn's API interface in a class and returning // that class object through this property. get { // TODO: Add ApplicationAddInServer.Automation getter implementation return null; } } #endregion } }
