Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor Node Label Updates
3 REPLIES 3
1174 Views, 3 Replies
I am attempting to rename a browser node. Here is the code I'm using and I'm getting a "Property 'Label' is 'ReadOnly'" error. In the API I found a note about using SetLabel() but that seems to only have  ones for ClientMade browser nodes.
 oSubAssyNode.BrowserNodeDefinition.Label = "XXX"
Any thoughts?
3 REPLIES 3
nagwani
You cannot definitly change the fixed nodes like Origin, X,Y,Z plane and Axes, but you can change the names of features,work geometry and sketches which were created by you.
Below is sample code taken from help, the sample code iterates the browser node tree changes changes the Label of Extrusion and Sketch through the Name property of native object.
Hope this helps!
-Ishwar N
Private Sub QueryModelTree()
    Dim Doc As Document
    If (ThisApplication.Documents.Count <> 0) Then
        Set Doc = ThisApplication.ActiveDocument
    Else
        MsgBox "There are no open documents!"
        Exit Sub
    Dim oTopNode As BrowserNode
    Set oTopNode = Doc.BrowserPanes("Model").TopNode
    Call recurse(oTopNode)
End Sub
Sub recurse(node As BrowserNode)
    If (node.Visible = True) Then
        Debug.Print node.BrowserNodeDefinition.Label
        If node.BrowserNodeDefinition.Label = "Sketch1" Then
            node.NativeObject.Name = "MySketch"
        If node.BrowserNodeDefinition.Label = "Extrusion1" Then
            node.NativeObject.Name = "MyExtrusion"
        Dim bn As BrowserNode
        For Each bn In node.BrowserNodes
            Call recurse(bn)
        Next
End Sub
in reply to: nagwani
Thanks so much. This worked perfectly.
linjone09
It cannot work in that situation.
Repair body's label.
