What is the Inventor 2015 ETO?
What are the differences between Inventor 2015 (normal) and Inventor 2015 ETO?
Developments for Inventor 2015 will work in Inventor ETO too?
Thanks & Regards,
Rui
Solved by philippe.leefsma. Go to Solution.
Inventor ETO sits on top of Inventor professional, so if your add-in is compatible with Inventor, it should load in ETO as well.
Here is the product overview:
http://www.autodesk.com/products/inventor-engineer-to-order/overview
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292
Philippe.
