In the assembly environment, It is possible to check if I can analyze whether a point is contained within a certain region? (Solid or define a space in 3D)?
I don't think it's possible directly. You can define an axis aligned bounding box by creating a Box object and use Box.Contains Method. For checking if a point is contained inside a solid, you could use TransientBRep.DoBoolean:
- Create a tiny spherical transient solid, using tolerance as radius
- Check volume of each solids
- Do a boolean union between both
- Check volume of result, if volume is smaller than sum of two volumes, the solids intersect.
I hope it helps,
Philippe.
