I've got a single machine that exhibits this behavior on both Inventor 2013 and now 2014. I can't seem to find a post anywhere that would suggest what the issue is. I have a ilogic macro that fills in the iproporties of Project/Project based on file name and a look up to excel. I know i could do it inside of ilogic or a text file but it is easier to modify in excel and does work on all other comptuters and use to work on this one. When Inventor is first opened, and you open a drawing and run the macro for the first time you get this error.
oFileName = ThisDoc.FileName(False) 'without extension Dim _Folder As String Dim F_Finder As String 'If iProperties.Value("Project", "Project")= NullString 'iProperties.Value("Project", "Part Number") F_Finder = (Left(oFileName,4)) 'GoExcel.Open("C:\Vault_Workspace\Folders.xlsx", "Sheet1") 'GoExcel.TitleRow = 1 i = GoExcel.FindRow("C:\Vault_Workspace\Folders.xlsx", "Sheet1", "Part" , "=", F_Finder) _Folder = GoExcel.CurrentRowValue("Folder") iProperties.Value("Project", "Project") = PDF_Folder 'End If _Folder = iProperties.Value("Project", "Project")
then if you run it again you get the this error.
Now this error would make sense if the part number isn't in the list, but it is normally.
Anyone have any insight into why both 2013 & 2014 would be doing this? Next to going back to a old restore point which for some reason would be back in 2010 and re-installing 2013 again. i'm at a loss.
Solved by Ktomberlin. Go to Solution.
Have you tried repairing your Microsoft Office installation through Add/ Remove programs in the Control Panel?
Yes i did yesterday after i posted this thread. The error does point to office.
System.Runtime.InteropServices.COMException (0x80040155): Interface not registered (Exception from HRESULT: 0x80040155)
at Microsoft.Office.Interop.Excel.ApplicationClass.get_LanguageSettings()
I was trying to see if it was a Net Framework issue as well. I found this
but these registry keys seem to exist and be configured correctly.
Hi Ktomberlin,
Machine specific issues are hard to address... I doubt anyone will be able to give you some insights to what the issue is. As far as I'm aware this behavior has never been reported before. My initial thought would have been the same than what thomaskennedy suggested, that is trying a repair of your Office install. A more extreme thing to try is a full uninstall/reinstall of Office, or at least Excel.
You may want to try directly from VBA and see if you can reproduce the issue there. If you don't you may want to invoke the working VBA code from iLogic instaed.
I hope it helps,
Philippe.
Success. Finally had the time to completely un-install Inventor 2014 & 2013 suites, clean the registry and re-install 2013 with all service packs and udpates. The error does not come up when using the call to excel to look for a cell.
Thanks for trying to help.
We also encountered this error, had a new Dekstop setup with Inventor 2014 and Office 2016. Which should work accourding this thread.
http://forums.autodesk.com/t5/installation-licensing/inventor-2014-excel-compatibility/td-p/5848094
We are also trying to figure out what to do next.
