Insert a DataGrid View into a Drawing
2 REPLIES 2
jpchaisson
456 Views, 2 Replies
Hi Everyone,
I ve got this idea but not sure where to begin or if its possible to do in Inventor.
Does anyone know how or if its possible to insert a DataGrid into a Inventor drawing using VB or C#
i would think this may be possible, if you think out it a "Parts List" is a DataGrid.
if anyone can help with this id appreiciate it.
Jeremy
2 REPLIES 2
FarrenYoung
in reply to: jpchaisson
Can you explain in more detail you envision this working?
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
thomaskennedy
Take a look at the 'Programming Help' in Inventor (click the '?' > Community Resources > Programming Help)
There's a good example in there to create a custom table :
Public Sub CreateCustomTable()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Set the column titles
    Dim oTitles(1 To 3) As String
    oTitles(1) = "Part Number"
    oTitles(2) = "Quantity"
    oTitles(3) = "Material"
    ' Set the contents of the custom table (contents are set row-wise)
    Dim oContents(1 To 9) As String
    oContents(1) = "1"
    oContents(2) = "1"
    oContents(3) = "Brass"
    oContents(4) = "2"
    oContents(5) = "2"
    oContents(6) = "Aluminium"
    oContents(7) = "3"
    oContents(8) = "1"
    oContents(9) = "Steel"
    ' Set the column widths (defaults to the column title width if not specified)
    Dim oColumnWidths(1 To 3) As Double
    oColumnWidths(1) = 2.5
    oColumnWidths(2) = 2.5
    oColumnWidths(3) = 4
    ' Create the custom table
    Dim oCustomTable As CustomTable
    Set oCustomTable = oSheet.CustomTables.Add("My Table", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _
                                        3, 3, oTitles, oContents, oColumnWidths)
    ' Change the 3rd column to be left justified.
    oCustomTable.Columns.Item(3).ValueHorizontalJustification = kAlignTextLeft
    ' Create a table format object
    Dim oFormat As TableFormat
    Set oFormat = oSheet.CustomTables.CreateTableFormat
    ' Set inside line color to red.
    oFormat.InsideLineColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
    ' Set outside line weight.
    oFormat.OutsideLineWeight = 0.1
    ' Modify the table formats
    oCustomTable.OverrideFormat = oFormat
End Sub
