Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Importing drawing resources
4 REPLIES 4
robmatthews
861 Views, 4 Replies
Inventor 9 (not 2009)...
I have an old drawing, and I want to replace the Title block with that from our newer template.
Private Sub BorderTitleBlock()
Dim oIDWDoc As DrawingDocument
Set oIDWDoc = ThisApplication.ActiveDocument
Dim oSourceFile As DrawingDocument
Dim oSheet As Sheet
Dim oTitleBlock
Dim SourceFileName As String
Dim ActiveTitleBlockName As String
Dim oTBDef As TitleBlockDefinition
Dim bFound As Boolean
For Each oSheet In oIDWDoc.Sheets
Set oTitleBlock = oSheet.TitleBlock
ActiveTitleBlockName = oTitleBlock.Definition.Name
If ActiveTitleBlockName <> "HCTitleBlock Metric" Then
oTitleBlock.Delete
For Each oTBDef In oIDWDoc.TitleBlockDefinitions
If oTBDef.Name = "HCTitleBlock Metric" Then
bFound = True
Set oTitleBlock = oSheet.AddTitleBlock(oIDWDoc.TitleBlockDefinitions.Item("HCTitleBlock Metric"))
Exit For
End If
Next
If Not bFound Then
SourceFileName = "\\brisbane-fs01\CAD_SERV\Inventor\Templates9\Standard.idw"
Set oSourceFile = ThisApplication.Documents.Open(SourceFileName, False)
oIDWDoc.TitleBlockDefinitions.Add (oSourceFile.TitleBlockDefinitions("HCTitleBlock Metric")) 'this is incorrect... What should i have here?
Set oTitleBlock = oSheet.AddTitleBlock("HCTitleBlock Metric")
oSourceFile.Close
Set oSourceFile = Nothing
End If
End If
Next
End Sub
If i just say :
Set oTitleBlock = oSheet.AddTitleBlock(oSourceFile.TitleBlockDefinitions("HCTitleBlock Metric")) then the correct titleblock is not added to the titleblock collection, and the text is formatted and placed incorrectly.
So how do "copy" drawing resources from one idw to another?
This is my signature, not part of my post.
4 REPLIES 4
robmatthews
in reply to: robmatthews
This also is not valid, although my thinking is that it is exactly what i want to do... Add a new (copied) titleblock to the TitleBlockDefinitions collection.
oIDWDoc.TitleBlockDefinitions.AddTitleBlock (oSourceFile.TitleBlockDefinitions("HCTitleBlock Metric"))
Is this at all possible? Or must I create a new (blank) titleblock using TitleBlockDefinitions.Add and then somehow incorporate all our functionality?
You first need to copy the definition over from the source document to the
target document. You can't use a definition from a different document.
Unfortunately for you, the API to copy titleblock definitions across
documents was also added in Inventor 10.
Sanjay-
robmatthews
Thank you for your response, Sanjay. That will stop me banging my head against the wall, trying to find the solution...
I guess that will be a manual operation then.
Cheers.
For Inventor 2010:
Delete old resources:
Dim oDocument As DrawingDocument
Dim oSheet As Sheet
Dim oPane As BrowserPane
Dim oDocumentNode As BrowserNode
Dim oDrawingResourceNode As BrowserNode
Dim oSheetFormatsNode As BrowserNode
Dim oBordersNode As BrowserNode
Dim oTitleBlocksNode As BrowserNode
Dim oSBsNode As BrowserNode
Set oDocument = ThisApplication.ActiveDocument    'Delete titleblock on sheet
If Not oDocument.ActiveSheet.TitleBlock Is Nothing Then
For Each oSheet In oDocument.Sheets
oSheet.TitleBlock.Delete
Next
End If
'Delete border on sheet
If Not oDocument.ActiveSheet.Border Is Nothing
Then
oSheet.Border.Delete
oSheet.AddDefaultBorder
Next
End If
oDocument.BrowserPanes.Item("Model").Activate
'Delete Drawing Resources
Set oPane = oDocument.BrowserPanes.ActivePane
Set oDocumentNode = oPane.TopNode
Set oDrawingResourceNode = oDocumentNode.BrowserNodes.Item("Drawing Resources")    oDrawingResourceNode.DoSelect
'Delete Sheet Formats
Set oSheetFormatsNode = oDrawingResourceNode.BrowserNodes.Item("Sheet Formats")
For Each oSheetFormatsNode In oSheetFormatsNode.BrowserNodes
oSheetFormatsNode.DoSelect
ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute
Next
'Delete Borders
Set oBordersNode = oDrawingResourceNode.BrowserNodes.Item("Borders")
For Each oBordersNode In oBordersNode.BrowserNodes
oBordersNode.DoSelect
Next
 'Delete Title Blocks
Set oTitleBlocksNode = oDrawingResourceNode.BrowserNodes.Item("Title Blocks")
For Each oTitleBlocksNode In oTitleBlocksNode.BrowserNodes
oTitleBlocksNode.DoSelect
Next
'Delete Sketched Symbols
Set oSBsNode = oDrawingResourceNode.BrowserNodes.Item("Sketched Symbols")
For Each oSBsNode In oSBsNode.BrowserNodes
oSBsNode.DoSelect
Next
AddNewTitleblock
' Open the new drawing to copy the title block into.
Dim oSourceDocument As DrawingDocument
Dim oSourceTitleBlockDef As TitleBlockDefinition
Dim oNewTitleBlockDef As TitleBlockDefinition
Dim oSPane As BrowserPane
Dim aPane As BrowserPane
Dim oSNode As BrowserNode
Dim oSDRNode As BrowserNode
Dim oSTitle As BrowserNode
Dim aDocNode As BrowserNode
Dim aDrResNode As BrowserNode
Dim aTBNode As BrowserNode
Dim oSheet As Sheet
Set oSourceDocument = ThisApplication.Documents.Add(kDrawingDocumentObject, "\\foo\Inventor2010\Templates\Standard_ISO.idw", True)
Set oSourceTitleBlockDef = oSourceDocument.ActiveSheet.TitleBlock.Definition
Set oSPane = oSourceDocument.BrowserPanes.Item("Model")
Set oSNode = oSPane.TopNode
Set oSDRNode = oSNode.BrowserNodes.Item("Drawing Resources")
Set aPane = oDocument.BrowserPanes.ActivePane
Set aDocNode = aPane.TopNode
Set aDrResNode = aDocNode.BrowserNodes.Item("Drawing Resources")
' Kopiëer Title Blocks
oSourceDocument.Activate
Set oSTitle = oSDRNode.BrowserNodes.Item("Title Blocks")
oSTitle.EnsureVisible
oSTitle.DoSelect
ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd").Execute
oDocument.Activate
aDrResNode.DoSelect
Set aTBNode = aDrResNode.BrowserNodes.Item("Title Blocks")
aTBNode.EnsureVisible
aTBNode.DoSelect    ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd").Execute
' Kopiëer Sketched Symbols
Set oSTitle = oSDRNode.BrowserNodes.Item("Sketched Symbols")
oSTitle.DoSelect
oDocument.Activate
aDrResNode.DoSelect
Set aTBNode = aDrResNode.BrowserNodes.Item("Sketched Symbols")
aTBNode.DoSelect
oSourceDocument.Close
' Get the new title block definition.
'Set oNewTitleBlockDef = oSourceTitleBlockDef.CopyTo(oDocument)
' Iterate through the sheets.
oSheet.Activate
Call oSheet.AddTitleBlock("ISO")
Next
Maybe there is a faster way?
Greetz Harm Uenk
