Hi
This rule help me when i export sheet metal dxf(when the iproperty LASER=X)with associated dxf add-in(from mcad)
the rule is used to name the dxf and for other stuff in drawing , the rule run fine with 2011 (french) but with 2012 (english) it's fail and i can find why
i think it's issue with iproperty language
someone can help me?
i've a lot of files with this rule to migrate
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 4110
StartFragment: 314
EndFragment: 4078
StartSelection: 314
EndSelection: 314
DXFtjd=iProperties.Value("Custom", "LASER")
If DXFtjd="X" Then
iProperties.Value("Custom", "Nom_DXF")=iProperties.Value("Custom", "DXFNAME")
ElseIf DXFtjd="" Then
iProperties.Value("Custom", "Nom_DXF")=""
End If
RuleParametersOutput()
DXFNAME=<part number> <revision number>
I can supply the data set for autodesk employe
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
