Ilogic View Reps on dwg
3 REPLIES 3
1021 Views, 3 Replies
HI
I am after help on some ilogic code ,I have had some code done to isolate selected parts in a assembly file that has a specific custom property filled in i.e. : DESC2.It then creates view reps and locks down giving the rep name the same name as part.
What I am after if any one can help is some code that will place these isolated view reps as views on my dwg that the assembly resides in.With the functionality of picking face to show plan view of parts.
Any thoughts would be appreciated.
Dave
Tags (3)
3 REPLIES 3
xiaodong_liang
If I understand correctly, you want to place the drawing views from one assembly in specific view reps (or even specific LOD etc) like UI does (see attachment). If yes, you could use Advanced API of ilogic to access Inventor API. DrawingViews.AddBaseView allows you to specify additional or advanced options:
Name
Value Type
Valid Document Type
WeldmentFeatureGroup
Weldment
SheetMetalFoldedModel
Boolean
Sheet Metal
String
Part, Assembly
DesignViewAssociative
Boolean
Part, Assembly
String
Assembly
MemberName
String
Part, Assembly
PresentationView
String
Presentation
PresentationViewAssociative
Boolean
Presentation
Following is a demo code I converted from the sample in the help reference of Inventor API:
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' Create a new NameValueMap object
Dim oBaseViewOptions As NameValueMap
oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Set the representations to use when creating the base view.
'Call oBaseViewOptions.Add("PositionalRepresentation", "MyPositionalRep")
Call oBaseViewOptions.Add("DesignViewRepresentation", "Default")
'Call oBaseViewOptions.Add("DesignViewAssociative", True)
' Open the model document (corresponding to the "MyLODRep" representation).
Dim strFullDocumentName As String
strFullDocumentName = ThisApplication.FileManager.GetFullDocumentName("c:\temp\reps.iam", "Master")
Dim oModel As Document
oModel = ThisApplication.Documents.Open(strFullDocumentName, False)
' Create the placement point object.
Dim oPoint As Point2d
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
' Create a base view.
Dim oBaseView As DrawingView
 oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 2, _
kIsoTopLeftViewOrientation, kHiddenLineRemovedDrawingViewStyle, _
, , oBaseViewOptions)
Anybody know to take the designviewreprentation, to see if is a front, side, top view in a drawing?
same to that
CurrentOrientation = activesheet.View("View1").DesignViewRepresentation
Thnaks for your help!
Ok i have now 🙂
Dim odoc As DrawingDocument
odoc = ThisApplication.ActiveDocument
Dim tmpView As DrawingView
'Which text for which orientation
Select Case tmpView.Camera.ViewOrientationType
Case ViewOrientationTypeEnum.kBackViewOrientation
iProperties.Value("Custom", "TEST") = "Back View"
Case ViewOrientationTypeEnum.kBottomViewOrientation
iProperties.Value("Custom", "TEST")= "Bottom View"
Case ViewOrientationTypeEnum.kFrontViewOrientation
iProperties.Value("Custom", "TEST") = "Front View"
Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
iProperties.Value("Custom", "TEST") = "Iso - Bottom Left View"
Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
iProperties.Value("Custom", "TEST")= "Iso - Bottom Right View"
Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
iProperties.Value("Custom", "TEST") = "Iso - Top Left View"
Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
iProperties.Value("Custom", "TEST")= "Iso - Top Right View"
Case ViewOrientationTypeEnum.kLeftViewOrientation
iProperties.Value("Custom", "TEST") = "Left View"
Case ViewOrientationTypeEnum.kRightViewOrientation
iProperties.Value("Custom", "TEST")= "Right View"
Case ViewOrientationTypeEnum.kTopViewOrientation
iProperties.Value("Custom", "TEST") = "Top View"
Case Else
iProperties.Value("Custom", "TEST") = ""
End Select
