I would like to constrain any parts in an assembly, that are not currently constrained, to an assembly UCS labeled UCS1.
I currently manually constrain parts (part UCS to assembly UCS) and it is extremely repetitive. Can anyone help me out with iLogic to check and see if a part is constrained, and if not it is not constrained, then constrain the part UCS to assmebly UCS.
Paul
Hi Paul,
I had a look and this is what I could come up with:
http://adndevblog.typepad.com/manufacturing/2014/07/create-ucs-constraints.html
Cheers,
Hi Adam,
Can you please provide insight on how to apply the code? I tried to drop it into iLogic in Inventor 2015, but received errors (cannot compile rule).
You just have to work through those errors.
1) First you'll get:
So you rename CheckUcsConstraints function to Main and move that whole function to the beginning of the rule.
2) Then you'll get:
So you remove all the Set keywords and when wpp is used for a second time in the code (inside CreateGeometryProxy), you declare a separate variable for that (e.g. wpp2)
And here is the end result that works:
Sub Main() ' Check if occurrences have a UCS1 and if it's constrained already Dim asm As AssemblyDocument asm = ThisApplication.ActiveDocument ' Using error handling in case ' not all components have a UCS1 On Error Resume Next Dim asmUcs1 As UserCoordinateSystem asmUcs1 = _ asm.ComponentDefinition.UserCoordinateSystems("UCS1") ' Each WorkPlane of the UCS must be constrained Call CreateFlushConstraints(asmUcs1.XYPlane, 0) Call CreateFlushConstraints(asmUcs1.XZPlane, 1) Call CreateFlushConstraints(asmUcs1.YZPlane, 2) On Error Goto 0 End Sub Function GetAllOccurrences(ByVal cd As AssemblyComponentDefinition) As ObjectCollection Dim coll As ObjectCollection coll = ThisApplication.TransientObjects.CreateObjectCollection Dim occ As ComponentOccurrence For Each occ In cd.Occurrences Call coll.Add(occ) Next GetAllOccurrences = coll End Function Sub CreateFlushConstraints(wp As WorkPlane, plane As Integer) Dim acd As AssemblyComponentDefinition acd = wp.Parent Dim coll As ObjectCollection coll = GetAllOccurrences(acd) Dim obj As Object For Each obj In wp.Dependents If TypeOf obj Is FlushConstraint Then Dim f As FlushConstraint f = obj ' Get other entity Dim other As Object If f.EntityOne Is wp Then other = f.EntityTwo Else other = f.EntityOne End If ' If it's a WorkPlane proxy ' then it's from an occurrence If TypeOf other Is WorkPlaneProxy Then Dim wpp As WorkPlaneProxy wpp = other Call coll.RemoveByObject(wpp.ContainingOccurrence) End If End If Next ' Create Flush Constraint for the remaining occurrences Dim occ As ComponentOccurrence For Each occ In coll Dim ucs As UserCoordinateSystem ucs = occ.Definition.UserCoordinateSystems("UCS1") Dim occWp As WorkPlane Select Case plane Case 0 occWp = ucs.XYPlane Case 1 occWp = ucs.XZPlane Case 2 occWp = ucs.YZPlane End Select Dim wpp2 As WorkPlaneProxy Call occ.CreateGeometryProxy(occWp, wpp2) Call acd.Constraints.AddFlushConstraint(wp, wpp2, 0) Next End Sub
Cheers,
