I've created a button that I've implemented into inventor. However I am at a loss as to how to create an icon for the button. I've read all the articles i can find (such as)
http://modthemachine.typepad.com/my_weblog/2008/11/creating-buttons-for-vba-macros.html
I've restarted the program and the computer multiple times but to no avail.
If I had hair I'd be pulling it out.
Suggestions please.
Solved by YuhanZhang. Go to Solution.
Currently there is a bug in Inventor 2013 for display the large icon of the macro command when you place it onto the ribbon panel, but if you display the small icon it should work. You can check the status of the bug status with providing the ID1463005 to us.
After changing it to a small icon and restarting my computer the button showed up. I guess this will sufice.
This has been fixed in Inventor 2014 SP1.
You're still limited to a small button in Inventor 2013.
Hello Ekinsb
I'm using Inventor 2014 pro with SP1, SP2, SP2-1
and the Icon I get for all macro's are all like this (the small format is working fine)
the name of the icon is
in my project.ivb
Public Sub ForQuotation()
Am I doing something wrong?
After having put all the icon to small and back to large, it's working also for large icon.
