If you are trying to execute different code depending on what type of object you have, then a slick way to do this is to create a map (or associative container, I don't know exactly what they call it in C#). For the key use the Microsoft.VisualBasic.Information.TypeName(...) function (this returns a string), and for the value store a functor. Then you can loop thru the objects and grab the appropriate functor out of the map. This avoids having a huge, slow, "if...then...elseif...else" branching statement.
Although, if you only have to handle a few object types, then this may be more overhead than is required.
