ILogic : browse to select a file
5 REPLIES 5
TONELLAL
4546 Views, 5 Replies
Is it possible in iLogic to select a file in a dialog box or a browser ?
I need to replace the 3d model on a drawing. I have to ask the user to select the new file to use. How can I select the file using a dialog box or a browser ?
The best should be a combobox with the list of opened files, and a button to browse on the disk, like when you create a view.
5 REPLIES 5
Hi TONELLAL,
You can use something along these lines:
'present a File Selection dialog
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
End if
MessageBox.Show("You selected: " & selectedfile , "iLogic")
 But I'm not sure about the combo box and buttons you mentioned.
I hope this helps.
Curtis
Curtis,
Found this post. Exactly what I needed. Awesome. Thanks!!
pontuti11
in reply to: FireBallFab
is there a way to then save the selected file's name and path and remove the extension (iam)? I would like to write a section of code to save the idw with the selected files name
DRLTKSE
in reply to: pontuti11
You could take Curtis' code and do something like:
SyntaxEditor Code Snippet
Dim oDoc As Document = ThisDoc.Document
Dim DrawingFileName As String
oFileDlg.ShowOpen()
    Return
End If
DrawingFileName = Left(selectedfile, ((Len(selectedfile)-3))) & "idw"
oDoc.SaveAs(DrawingFileName, False)
I'm sure there is an easier way to change the file extension; selectedfile.ExtensionTo(.idw) or something like that but this code should work as it is for you
i.pous
in reply to: Curtis_Waguespack
is posible to select a folder?how?
