I’m looking for a little help again with i logic
is it possible to change the colour of all elements in a pattern without changing the ipt file?
I have an assembly that has 4 rectangular patterns that can have any number of elements, sometimes the customer will ask for coating to be applied, in this case i only want to change the colour at the assembly level only.
Thanks in advance
Steve
If you know what is the total number of all cpomponents you can do this.
Add a text parameter MyColor to your Assembly and add this rule
MultiValue.SetList("MyColor","White","Red","...") For i=1 To 50 Component.Color("ComponentName:"& i )=MyColor Next i InventorVb.DocumentUpdate()
Of course the name of color must be the same that exist in the library.
