Inventor Customization
Distinguished Contributor
Message 1 of 5 (695 Views)
How to test for EVEN or ODD variable values with iLogic 2012?
695 Views, 4 Replies
07-03-2011 02:02 PM
I'm attempting to build a sheet metal panel in a rectangular pattern both vertically and horizontally.  All holes in pattern are to be the same size.  The other criteria that the pattern MUST follow is that the hole pattern itself, whether square or rectangular MUST BE CENTERED on the sheet metal face.
Using an iLogic Form, I am able to drive the dimensions for the sheet itself, the hole diameter, the number of rows and the number of columns.  I am also able to input offsets both/either vertically or horizontally.  When either or both the Number of Rows or the Number of Columns is odd, one (1) hole centrally placed on the sheet metal face allows  for my design intent to work properly.  When the hole pattern requires either an even number of Rows or Columns, an offset is needed.  Through some experimentation, I've been able to figure out the amount of displacement required to center this type of hole pattern.
What I'm in need of is code to test that either the Number_of_Rows value is even or odd and Number_of_Columns is either even or odd.  After testing for even or odd iLogic needs to update the hole location both horizontally and/or vertically as needed.  Instructions on how to update variable with iLogic are also needed.  I'm a newbie!  :smileysad:
Code would be similar to the following:
Test Number_of_Rows for "oddness"
If Number of Rows is odd then
  oHOFFSET = 0
 ELSE oHOFFSET = 3
Parameter ("Horizontal_Offset") = 3
END IF
Any tips, suggestions or errata on testing a value for being even or odd would be greatly appreciated!
Jim Strenk
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012, 2013 & 2014
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
BrentDouglas
Message 2 of 5 (690 Views)
Re: How to test for EVEN or ODD variable values with iLogic 2012?
07-03-2011 10:34 PM in reply to: JimStrenk
The modulo operator is what you're looking for (Mod in iLogic or % pretty much everywhere else). It returns the remainder after a division.
If NumberOfRows Mod 2 = 0 Then
	//Do even things
Else
	//Do odd things
End If
Message 3 of 5 (684 Views)
07-03-2011 11:00 PM in reply to: BrentDouglas
	//Do even things
Else
	//Do odd things
End If
Since I wish to test Odd first, I should use the following code:
If Number_of_Rows Mod 2 = 1 Then
  // Do odd things
ELSE
  // Do even things
End If
Would that be correct?
Thank you for your assistance.  It is greatly appreciated!
Jim Strenk
BrentDouglas
Message 4 of 5 (680 Views)
07-03-2011 11:21 PM in reply to: JimStrenk
That's correct. Glad I could help.
Message 5 of 5 (675 Views)
07-04-2011 01:25 AM in reply to: BrentDouglas
Thanks a million!  I've just finished cigarette pack #3 trying to figure this stuff out.
Jim Strenk
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
