Any one know how to set the visibility of workplanes in an assembly file to false.???
Solved by arunkgvm. Go to Solution.
Solved by jdkriek. Go to Solution.
This may help if you are refereing to all sub components as well as the active document.
http://inventortrenches.blogspot.com/2013/03/turn-onoff-all-workfeatures-with-ilogic.html
Thanks a lot..its working fine..... there is already some work plane's visibility false but when I open the inventor using vb.net code they are showing.I change the view by code then it will okey.here is the code
Dim doc As AssemblyDocument = inventorApp.ActiveDocument
Dim ADef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim dRepMgr As RepresentationsManager = ADef.RepresentationsManager
Dim dRep As DesignViewRepresentation = dRepMgr.ActiveDesignViewRepresentation
dRep = dRepMgr.DesignViewRepresentations.Item(2)
dRep.Activate()
