Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to read an ADSKLIB file ?
7 REPLIES 7
Message 1 of 8
TONELLAL
12411 Views, 7 Replies
I've created a dialog box where I have a combobox containing materials. This combobox has to be filled with library materials, not with ipt materials. While materials were stored in an xml file, it was easy to read it. Now they are stored in an adsklib file, how can I read it ?
7 REPLIES 7
Message 2 of 8
philippe.leefsma
in reply to: TONELLAL
Rename the file in .zip, unzip, and you will find several .xml in the package.
This is an unsupported topic, so extracting information from there will need to be achieved on your own.
I hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
TONELLAL
Thanks Philippe for your answer. I tried to unzip some files, there are a lot of error messages ("Invalid filename in the archive xxx_png") for all custom libraries, for the standard libraries no error messages but it is impossible to use them... If in addition it is unsupported it is not worth...
So, how can I obtain the list of all materials existing in the libraries declared in an ipj file ? I can read materials in an ipt, but ipt and libraries can have their own materials. The purpose is to obtain all libraries materials (even those which are not loaded in the part), and not local materials.
Message 4 of 8
philippe.leefsma
Other than opening the part to read materials in it, I don't see a way to achieve that...
You can iterate all local librairies as follow:
Public Sub DumpAllAppearancesInAllLibraries()
    ' Open a file to write the results.
    Open "C:\Temp\AllLibAppearanceDump.txt" For Output As #1
    ' Iterate through the libraries.
    Dim assetLib As AssetLibrary
    For Each assetLib In ThisApplication.AssetLibraries
        Print #1, "Library" & assetLib.DisplayName
        Print #1, "  DisplayName: " & assetLib.DisplayName
        Print #1, "  FullFileName: " & assetLib.FullFileName
        Print #1, "  InternalName: " & assetLib.InternalName
        Print #1, "  IsReadOnly: " & assetLib.IsReadOnly
        Dim appearance As Asset
        For Each appearance In assetLib.AppearanceAssets
            Print #1, "    Appearance"
            Print #1, "      DisplayName: " & appearance.DisplayName
            Print #1, "      Category: " & appearance.Category.DisplayName
            Print #1, "      HasTexture: " & appearance.HasTexture
            Print #1, "      IsReadOnly: " & appearance.IsReadOnly
            Print #1, "      Name: " & appearance.Name
            Dim value As AssetValue
            For Each value In appearance
                Call PrintAssetValue(value, 8)
            Next
        Next
    Next
    Close #1
    MsgBox "Finished writing output to ""C:\Temp\AllLibAppearanceDump.txt"""
End Sub
 Philippe.
Philippe Leefsma
Message 5 of 8
TONELLAL
in reply to: philippe.leefsma
Ok ! So it is possible to access to the appearances and materials in the libraries files, by opening the part.
Thanks !
Message 6 of 8
TONELLAL
After some tests, I found I can use ThisApplication.DesignProjectManager.ActivedesignProject.AppearanceLibraries or .MaterialLibraries, to access to the libraries defined in the project file, without opening a part.
Message 7 of 8
damhiep99
Can you do a tutorial how to do it. Thanks
Message 8 of 8
TONELLAL
in reply to: damhiep99
Here's the code for appearances, to put in the Form code :
Private Sub UserForm_Initialize()
Dim oBiblis As AssetLibraries
Dim oBibli As AssetLibrary
Dim oProjectBiblis As ProjectAssetLibraries
Dim ligne(1)
'Get only Appearance libraries referenced by the current ipj
Set oBiblis = ThisApplication.DesignProjectManager.ActiveDesignProject.AppearanceLibraries
'Fill the libraries list
For Each oBibli In oBiblis
Liste_biblis.AddItem oBibli.DisplayName
Next oBibli
'Initialize the list on the 1st value
Liste_biblis.Value = Liste_biblis.List(1)
End Sub
Private Sub Liste_biblis_Change()
Dim oAppearances As AssetsEnumerator
Dim oAppearance As Asset
'Get the name of the library selected in the Libraries list
Set oBibli = ThisApplication.AssetLibraries.item(Liste_biblis.Value)
'Get the appearances
Set oAppearances = oBibli.AppearanceAssets
'Fill the list
Liste_apparences.Clear
For Each oAppearance In oAppearances
Liste_apparences.AddItem oAppearance.DisplayName
Next oAppearance
End Sub
