Inventor Customization
Active Contributor
Message 1 of 3 (176 Views)
How to make a new Template?
176 Views, 2 Replies
01-31-2013 01:36 AM
Hi all,
I got a .DWG drawing from a client, and tey want me to implement that template on Inventor for the furthere drawings for this new project.
Can any one help me and learn me how to make/create/ customize a newTaemplate in Inventor?
Thank you in advance
Sohaib
Valued Contributor
Message 2 of 3 (160 Views)
Re: How to make a new Template?
02-04-2013 01:59 AM in reply to: sohmoh
Hi Sohaib
When you say "implement that template on Inventor" do you then mean, implementing functions in the template, settings, og do you mean the titleblock.
As i understand you you mean title block... makes most sense to me :smileyhappy:
Making a template is relatively easy, you just save your (in this case) IDW, in the Template folder. See Application Options --> File, or look in your project file, that can be set up to overrule it.
If you start a new IDW you can choose to create a new title block, and then you should be able to copy - paste the titleblock from the DWG you got from a client.. you will propably need to adjust it to make it fit and so on...
Hope it helps you..
/LSA-Skan
Active Contributor
Message 3 of 3 (155 Views)
02-04-2013 02:24 AM in reply to: LSA-skan
Hi Sir
That's help me, thank you.
But when I copied the .dwg I missed the <prompts>, so I had to to it all again.
Thank you again
Sohaib
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
