Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to flatten cylinder
9 REPLIES 9
Message 1 of 10
949 Views, 9 Replies
Hello guys!
How to flatten this shape? (Pls. see attached file...this is not a complete circle there is some gap). I tried the unfold method but its not working.
Thanks.
Ber
9 REPLIES 9
Message 2 of 10
You'll probably have better luck asking this question in the
autodesk.inventor newsgroup, since it's a general use question and not a
programming issue.
Brian Ekins
Autodesk Inventor API
Message 3 of 10
Sorry I didn't tell that it was made by a macro. Here is the last part of the macro.
Dim oShaftBody As ExtrudeFeature
Set oShaftBody = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, sOD, kSymmetricExtentDirection, kIntersectOperation)
'Convert to SheetMetal environment
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
Dim oFlatPattern As FlatPattern
Set oFlatPattern = oSheetMetalCompDef.FlatPattern
oSheetMetalCompDef.Unfold
I tried this in UI, it can be flattened but i have to select first one of its surface. Unlike if i make something like square shape, selecting any face is unnecessary.
I am new to this IV programming. Pls help!
Message 4 of 10
'I just copied this from the sample
Ber
Message 5 of 10
There's an Unfold2 method that allows you to specify the base face for the
unfold. Here's the sample I used to test it for your case.
Public Sub UnfoldCylinder()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oSMDef As SheetMetalComponentDefinition
Set oSMDef = oPartDoc.ComponentDefinition
' Find one of the cylindrical faces of the part.
Dim oFace As Face
For Each oFace In oSMDef.SurfaceBodies.Item(1).Faces
If oFace.SurfaceType = kCylinderSurface Then
Exit For
Next
Call oSMDef.Unfold2(oFace)
End Sub
Brian Ekins
Message 6 of 10
Hi Brian,
I tried the code but it seems UNFOLD2 is not supported in IV 2008. Is there any workaround on this?
Ber
Message 7 of 10
You're right. That method is new for Inventor 2009. A workaround is to
drive the command through the API. It happens to be easy in this case
because the only input is to pre-select a face. The downside to doing this
is that the document needs to be visible and active. Here's the modified
code.
Dim oFace As Face
Exit For
Next
oPartDoc.SelectSet.Clear
oPartDoc.SelectSet.Select oFace
ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalFlatPatternCmd").Execute
End Sub
Brian Ekins
Message 8 of 10
Hi Brian!
I tried the new code but I am getting an error msg. Please see the attached error msg. I checked the default thickness and the model thickness, they are the same.
What I understand with the code is that; it is equivalent in the UI by selecting one of its cylindrical face before clicking the "Flat Pattern" icon, right? Because, if I do this manually the cylinder is flatten.
Please give me an idea what causing this error msg.
Ber
Message 9 of 10
My program just looks for the first cylindrical face it finds in the model.
I don't know exactly what your model looks like but possibly it's picking a
cylinder that's not valid for the starting face. If you debug and put a
break in the code just before it executes the command you can see in the
graphics window which cylinder is selected. You might need to improve the
logic on how it finds a cylinder. Without knowing more about your specific
model or workflow I can't really offer any suggestions.
Brian Ekins
Message 10 of 10
Hi Brian.
I solved the problem! Thank you for your time and suggestions. It helps a lot!
I attached the final output of the program.
Ber
