Hi
I have a script that makes PDF-file with suffix revision. Now I want to expand this script so it even makes a STEP-file of the 3d-file connected to the drawing. This would make all manufacture files in one button. That should be nice..
How will i manage with this since the active document is the drawing not the part. (see code below)
BR/Goran
Set oDoc = ThisApplication.ActiveDocument
Call oDoc.SaveAs("C:\Users\GoranWe\Desktop\test\testfile.stp", True)
Hi Gwennberg,
When working with a drawing file you can use ThisDoc.ModleDocument to reference the model.
Below is an example.
I hope this helps.
Curtis
'-------------export PDF file ------------------------------- 'Save PDF with options Dim oDocument As Inventor.DrawingDocument oDocument = ThisDoc.Document path_and_name = ThisDoc.PathAndFileName(False) ' without extension PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then 'oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the destination file name oDataMedium.FileName = path_and_name & ".pdf" 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) '-------------export step file ------------------------------- 'define the model referenced by the drawing Dim oModelDoc = ThisDoc.ModelDocument ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oSTEPContext As TranslationContext oSTEPContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oSTEPOptions As NameValueMap oSTEPOptions = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(oModelDoc, oSTEPContext, oSTEPOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oSTEPOptions.Value("ApplicationProtocolType") = 3 ' Other options... 'oSTEPOptions.Value("Author") = "" 'oSTEPOptions.Value("Authorization") = "" 'oSTEPOptions.Value("Description") = "" 'oSTEPOptions.Value("Organization") = "" oSTEPContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = ThisDoc.PathAndFileName(False) & ".stp" oSTEPTranslator.SaveCopyAs(oModelDoc, oSTEPContext, oSTEPOptions, oData) End If
Hi
I pasted your script as it was written into editorn but I got failure in the definition:
"Dim oModelDoc = ThisDoc.ModelDocument". Whats wrong?
/Goran
Goran, have you got the STP output working?
I've created iLogic rules for exporting PDF, DXF & STP. (With help from Curtis Waguespack's From the Trences blog)
The iLogic code that I use looks like this:
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(oModelDoc, oContext, oOptions) Then
'Options for STEP output
oOptions.Value("ApplicationProtocolType") = 3 'Set application protocol: 2 = AP 203 - Configuration Controlled Design, 3 = AP 214 - Automotive Design
oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName
oOptions.Value("Authorization") = ""
oOptions.Value("Tolerance") = "0.00001 mm"
oOptions.Value("Description") = iProperties.Value("Summary", "Title")
oOptions.Value("Organization") = "IKM Technique AS"
FilePath= ThisDoc.Path 'This .IDW's path
OutputPath = FilePath & "\" & "STP" 'Output destination for the new STP
OutputFileName = iProperties.Value("Custom", "Output File Name") & ".stp" 'Output File Name as specified in Custom iProperties, as specified by the iLogic rule OutputFileName
'Check for existance of STP folder and create if not found
If Not System.IO.Directory.Exists(OutputPath) Then
System.IO.Directory.CreateDirectory(OutputPath)
End If
'Set the destination path & file name
oData.FileName = OutputPath & "\" & OutputFileName
'Publish Document
oSTEPTranslator.SaveCopyAs(oModelDoc, oContext, oOptions, oData)
End If
I also export drawings with a revision suffix. I have another iLogic rule which runs automatically (Event Triggers) everytime the drawing is saved. This iLogic rule creates a custom iProperty containing current revision, which is used for the file names of the exported PDF, DXF and STP files. Which is why I specify export destination and file name the way I do.
Another way to retrieve model path and file name is by using this code:
ModelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
ModelPath = IO.Path.GetDirectoryName(ThisDrawing.ModelDocument.FullFileName)
Hi Ben Young
I pasted your script as it was written into editorn but I got failure this time also.
It will not accept syntax "Dim oModelDoc = ThisDoc.ModelDocument". Whats wrong?
BR
/Goran
It's not a simple matter of getting the model from the drawing since it's possible for drawing to reference multiple files. One approach is to use the ReferencedDocuments property of the DrawingDocument to get a list of documents directly referenced by the drawing. You can then write these out in whatever format you want.
I don't know why that didn't work for you. It works on all of the machines at my workplace.
What I posted was actually the from the 2nd time I wrote the script. I'll see if I can dig up the first version of it. It calls up the model in a slightly different way.
I'll get back to you.
That's a good point.
Though, the reason why it works for us is that we have only one part or one assembly per drawing.
Hi Gwennberg,
ekinsb's point is a very good one, and writing the code to identify a specific view and the model referenced by that view would be more robust, albeit a bit more involved.
Most times when we are saving a file to a STEP (around here) it is a Part file and that part file is the only one referenced on the drawing, but if that's not the case for you this code might not work for you as is.
As for your problems running this code, is it possible that you're trying to run this rule from the VBA editor rather than as an iLogic rule? Both of the examples are written for iLogic.
Here's a link that will help you set this up as an iLogic rule:
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
I have worked thought VBA editor so that must be the reason why it not works.
I also see the problem with many parts in a drawing but it would not be any problem since we never makes drawing that way.
Thanks agin all of you for your help.
BR/Göran
